Mathijsgri said:
i would say 30 seconds at the time at most.
Just to be sure, their is only a torque force if the wheel is accelerating, right?
If you expect the gyroscope to support a mass of 12 metric tons at an offset of 35 meters from the pivot point then there is most certainly a torque. That torque amounts to a rate at which angular momentum is dumped into the gyroscope.
If the gyroscope were a simple reaction wheel, this would be done by accelerating the wheel in the direction of the torque.
With a gyroscope one can, instead, rotate the gyroscope (a pair would be better) through some angle and allow the torque from precession to serve. However, you can only rotate a gyroscope through a maximum of 180 degrees before the torque from precession starts pointing the wrong way.
You cannot dump angular momentum into a gyroscope forever.
Edit: Let's put some rough numbers to this.
12 metric tons hanging on a beam 35 meters out from the pivot point. That's 12000 kg under a gravitational acceleration of 9.8 m/s^2. Approximately 120000 Newtons of force.
120000 Newtons on a 35 meter moment arm is 4.2 million Newton-meters of torque
Say we have a reaction wheel which is 1 metric ton and a radius of 1 meter. For simplicity, assume that the mass is all concentrated at the rim of the wheel. The moment of inertia of the wheel is given by mr
2. That's 1000 kg m
2.
The angular acceleration of the wheel is torque divided by moment of inertia. 4200 radians/s
2. Multiply by 30 seconds and the resulting angular velocity is 126000 radians/sec.
Divide by 2pi radians per revolution and multiply by 60 seconds per minute and you have 1.2 million rpm.
With a one meter radius the rim velocity is 126 kilometers per second.
The centripetal acceleration at the rim is given by v
2/r and works out to 1.6 billion g's.
Kinetic energy is given by ½mv
2 and works out to 8 terajoules of energy.
Over 30 seconds, the average power requirement to spin this up as a reaction wheel would have been 264 gigawatts.
We are going to need a bigger wheel.
