- Messages
- 13,556
- Reaction score
- 4,419
"Internal torque canceling an external torque" is exactly the kind of confused talk that leads nowhere.rcgldr said:...an internal roll torque reaction to yaw "cancels" an external roll torque...
External torques and forces are all we care about.rcgldr said:This doesn't change the fact that there is only one external torque that results in precession.
Because of angular momentum and energy conservation the gyro cannot just start precessing, while maintaining exactly the same spin rate and spin axis inclination. The precession motion itself has its own small angular momentum component around the vertical axis, which must be reflected by an equal but opposite change in the vertical angular momentum from the spin.rcgldr said:The gyro initially "drops a bit", and only after the drop has started does the gyro begin accelerating in the direction of precession.
And it is that small angular momentum component around the vertical axis that you need to remove to stop the yaw-precession.
