Discover the Physics Behind Balloon Movement in a Stopped Car
  • Thread starter Thread starter 21385
    Hard
When a car traveling at constant speed suddenly decelerates, a balloon inside the car moves backward relative to the car. This occurs due to a pressure gradient created by the deceleration, where the air inside the car maintains its speed, resulting in higher pressure at the front. As the car slows down, the balloon experiences a difference in pressure, causing it to move toward the area of lower pressure at the back. This phenomenon contrasts with a pendulum, which would swing forward in the same situation. Understanding this behavior highlights the effects of pressure dynamics in a decelerating environment.
21385
Question 20
You are traveling at constant speed in an airtight car with a
balloon floating motionless next to you. Suddenly, you slam
on the brakes so as to stop the car quickly. During decceleration,
with respect to the car the balloon
(a) moves forward; (b) remains motionless;
(c) moves backward; (d) can move forward or backward.
No Equations
The correct answer is c, that it moves backwards. Can someone explain why?
Thanks
Great problem. I don't know why. I can do some handwaving and say the air in the car, relative to the ground, has the same average speed as the car, as of course does the balloon. So when the car abruptly decelerates you get a gradient of pressure from highest to lowest from the windshield backwards, and this pressure change develops rapidly.
But this is one answer I might need to empirically validate.
Yes, it is because of a pressure gradient, inside the car the front part is in higher pressure, because as the car is decelerating the air tends to maintain the same speed so the majority of the air goes to the front part of the car, like there was some gravity attracting the air to there. If the pressure in the front part of the balloon is greater than the pressure behind he goes backwards. But if you have a pendulum, it would move forward.
  • · Replies 29 ·
  • · Replies 21 ·
  • · Replies 18 ·
