A harmonic wave with a frequency and an amplitude
The discussion centers on the analysis of a harmonic wave characterized by a frequency of 80Hz and an amplitude of 0.025m, traveling along a string at a speed of 12m/s. The correct wave function is identified as y(x,t) = A sin(2πft ± 2πx/λ + ϕ), emphasizing that wave functions must depend on both position (x) and time (t). Participants seek guidance on calculating maximum speed and maximum acceleration of points on the string, with definitions provided for velocity and acceleration as the rates of change of displacement and velocity, respectively.
  • Understanding of harmonic waves and wave functions
  • Knowledge of basic physics concepts such as velocity and acceleration
  • Familiarity with sinusoidal functions and their properties
  • Ability to apply mathematical principles to physics problems
  • Study the derivation of wave functions in wave mechanics
  • Learn how to calculate maximum speed and acceleration in harmonic motion
  • Explore the relationship between frequency, wavelength, and wave speed
  • Review simple harmonic motion and its applications in physics
Students of physics, educators teaching wave mechanics, and anyone interested in understanding the dynamics of harmonic waves and their properties.
Ammar2211
A harmonic wave with a frequency of 80Hz and an amplitude of 0.025m travels along a string to the right with a speed of 12m/s.
a) Write a suitable wave function for this wave.
b) Find the maximum speed of a point on the string.
c) Find the maximum acceleration of a point on the string.
y = f(x) = ASin(2πft + ϕ)
y(x,t)−y0=Asin(2πft±2πx/λ+ϕ)
For part (a), which generic function would be used? either y = f(x) = ASin(2πft + ϕ) or y(x,t)−y0=Asin(2πft±2πx/λ+ϕ) ??
Furthermore how to find out max. speed & max. acceleration of a point on the string?? Any directions please
A wave function must be a function of both ##x## and ##t##. To say ##f(x) = \sin(2\pi f t)## doesn't make mathematical sense. Your second equation is correct.
For parts b) and c), what does the wave motion consist of in terms of the motion of the string?
For part b & c, I am confused about how to compute, if you can help me I shall be thankful to you!
Anybody can help me to solve part b & c, and directions please...
A wave on a string is created by each point of the string moving up and down in simple harmonic motion. You can see that by fixing ##x = x_0## and then looking at how the string at the point ##x_0## moves over time.
PeroK said:
A wave on a string is created by each part of the string moving up and down in simple harmonic motion. You can see that by fixing ##x = x_0## and then looking at how the string at the point ##x_0## moves over time.
So, how to find out max. velocity & max. acceleration!
How are these defined?
This is the problem statement, I don't know what's your point!
How are velocity and acceleration defined?
I don't know, that's why I am asking here!
We can't teach you physics here, we can only help you with problems. To learn physics you need to be following a course or textbook or online lecture series or something of the sort. We would expect the source of your homwork question to have the material on which the question is based.
The subject matter here is harmonic waves and harmonic motion generally. If you really don't know what velocity and acceleration are, then you'll need to find some material on them. Without that you are not in a position to learn more advanced physics.
Velocity, v, is
v = \mathrm{\frac{change \ in \ displacment}{change \ in \ time}}
Another way to describe velocity is "rate of change of displacement."
Acceleration, a, is
a = \mathrm{\frac{change \ in \ velocity}{change \ in \ time}}
Another way to describe acceleration is "rate of change of velocity."
You already have the point's displacement, y as a function of time, t. So, find the rates of change, and then determine what the maximums are.
