A Heuristic View of QM: Axioms & Gleason's Theorem
  • Context: Undergrad
  • Thread starter Thread starter bhobba
    Qm
The discussion revolves around the axioms of quantum mechanics (QM) and the justification of QM formalism through intuitive reasoning, particularly focusing on the role of complex vector spaces and Gleason's theorem. Participants explore the implications of these concepts and their foundational significance in quantum theory.
  • Some participants propose that the formalism of QM can be justified intuitively through the use of hermitian operators and complex vector spaces, with eigenvalues representing possible outcomes of observations.
  • Others argue that mathematics is discovered rather than invented, suggesting that it underlies the relationships that lead to observable phenomena, although this leads to philosophical discussions.
  • There is a suggestion that the essential indeterminacy of reality necessitates the use of complex numbers in quantum descriptions, although this is met with requests for further clarification.
  • Some participants note that canonical commutation relations are essential for most of quantum mechanics and cannot be derived solely from Gleason's theorem, indicating a limitation in the axiomatic approach discussed.
  • A later reply introduces the idea that the complexity in quantum mechanics may relate to data compression and the stability of agents, proposing a more intuitive understanding of the necessity for complex state spaces.
  • There is contention regarding the adequacy of explanations provided, with some participants feeling that responses lack depth and merely express beliefs rather than detailed reasoning.
Participants express a mix of agreement and disagreement, with some supporting the intuitive justification of QM formalism while others challenge the sufficiency of the arguments presented. The discussion remains unresolved on several points, particularly regarding the necessity and implications of complex vector spaces in quantum mechanics.
Some participants highlight the dependence on definitions and the unresolved nature of certain mathematical steps in the discussion, particularly concerning the relationship between Gleason's theorem and canonical commutation relations.
Strictly speaking, this isn't about interpretations; it's about whether there is a way to justify QM formalism more intuitively. I put it here because it may help when discussing interpretations. I will let others decide on its implications or even if it is a valid way of viewing it.
Suppose two systems interact, and the result is several possible outcomes. We imagine that, at least conceptually, these outcomes can be displayed as a number on a digital readout. Such is an observation in QM. You may think all I need to know is the number. But I will be a bit more general than this and allow different outcomes to have the same number. To model this, we write the number from the digital readout of the ith outcome in position i of a vector. We arrange all the possible outcomes as a square matrix with the numbers on the diagonal. Those who know some linear algebra recognise this as a linear operator in diagonal matrix form. To be as general as possible, this is logically equivalent to a hermitian matrix in an assumed complex vector space where the eigenvalues are the possible outcomes. Why complex? That is a profound mystery of QM - it needs a complex vector space. Those that have calculated eigenvalues and eigenvectors of operators know they often have complex eigenvectors - so from an applied math viewpoint, it is only natural. But just because something is natural mathematically does not mean nature must oblige.
So we have the first Axiom of Quantum Mechanics:
To every observation, there exists a hermitian operator from a complex vector space such that its eigenvalues are the possible outcomes of the observation. This is called the Observable of the observation.
But nothing is mystical or strange about it, just a common sense way to model observations. The only actual assumption is it is from a complex vector space.
Believe it or not, that is all we need to develop Quantum Mechanics. This is because of Gleason's Theorem:
https://www.arxiv-vanity.com/papers/quant-ph/9909073/
This leads to the second axiom of QM.
The expected value of the outcome of any observable O, E(O), is E(O) = trace (OS), where S is a positive matrix of unit trace, called the state of a system.
These are the two axioms of QM from Ballantine.
Thanks
Bill
Mathemeatics is not invented but discovered. Evidently it underlies the relationships that eventually turn into observations and this is why everything is predictible. Until you hit the HUP, that is where the math forbids certain types of knowledge.
Math is neither a fluke nor a coincidence. Knowledge seems fundmental and math is the blueprint. Quantum fields, math and knowledge are the fundamental structure of reality.
Why complex vector space?
My guess is the essential indeterminancy of reality.
  • Skeptical
CoolMint said:
Why complex vector space? My guess is the essential indeterminancy of reality.
I actually agree with the first bit, but can you explain the above in more detail?
Thanks
Bill
Thanks
Bill
Both real and imaginary numbers are required to describe quantum systems, hence complex-valued behavior can be predicted using complex valued numbers at each point at time t. Why is this so?
The fundamental indeterminancy of the world will likely never allow a classical description without imaginary numbers and complex vector space.
  • Skeptical
For most of quantum mechanics you need the canonical commutation relations. This was Heisenberg's starting point, and cannot be deduced from Gleason's theorem!
That is a philosophical discussion.
This is not more detail. It is just an expression of your belief that it must be so.
Of course. For this you need the representation theory of the spacetime's symmetry group (Galilei or Poincare groups, depending on whether you want non-relativistic QM or relativistic QFT).
That's as in Newton's mechanics: You have a general valid set of postulates (including implicitly the space-time symmetry group btw), but there's no way to derive the concrete forces acting on the particles. This must come from empirical input, e.g., Newton's universal gravitational interaction force between point particles, which were discovered by analyzing which forces lead to the validity of Kepler's empirical law of planetary motion.
How is it my belief? This is textbook stuff.
You said this
And he asked you for more detail. And you responded by
How is this more detail!!!
I've been giving this a lot of thought as awell, in the spirit of "physics from inference" from the perspective of an inside agent, and I agree the complexity is one weird thing, and another weird thing is what one needs to use uncountable numbers to index distinguishable events. But this is hard to discuss as it's always fuzzy.
But to address the reason for complexity, my intuitive understanding of this is that it has todo with datacompression and stability of agents. The reason for the complex state, is that an agents optimal state of information needs a more efficient encoding. And we know fourier transform is used in datacompression(having nothing todo with QM per see), and for a good reason. And the conjugate spaces are essentially defined by the fourier transfom. So if you want in your state of information, statistical information about Q and P and the same time, you either up with with a complex number - or one could also consider several possible spaces, that are defined by relations. But the former way makes for a more compact notation!
So I think the reason is both datacompression and stability of agents, and that the complex state space makes for an efficent notation for human physicists.
imo, a generalisation of this gets us into various dualities principles where different theories in different spaces, can give the the same predictions on a common boundary. The difference lies more in efficiency of representation and computational complexlitry.
Is my loose intutive view... pulled out of my "agent interpretation"
/Fredrik
martinbn said:
You said this
I didn't. You cut out just 1 sentence from my reply and misrepresent it as my whole reply.Here is my full reply from post 4:
"Both real and imaginary numbers are required to describe quantum systems, hence complex-valued behavior can be predicted using complex valued numbers at each point at time t. Why is this so?
The fundamental indeterminancy of the world will likely never allow a classical description without imaginary numbers and complex vector space."
Nobody can say why things are as they are or why the laws of physics are what they are. What can be said is that the world appears to be fundamentally indeterminate.
I do not know why the world is indeterminate and neither I nor anyone else know more details why this is so.
I thought that was the purpose of Chapter 3 of Ballentine where Schrödinger's equation is derived. The physical assumption is the probabilities are frame independent ie the POR.
And yes, the Poisson Bracket approach is a very elegant way to derive the dynamics.
Thanks
Bill
For me, made up.
Right.
Thread locked pending moderation
After some cleanup and a Mentor discussion, the thread is reopened. A sockpuppet of a previously-banned member has been identified and banned now. Have a nice day. :smile:
  • · Replies 37 ·
  • · Replies 35 ·
  • · Replies 70 ·
  • · Replies 16 ·
  • · Replies 59 ·
14K
  • · Replies 28 ·
