A (nonconservative) electric field is induced in any region in which...
The discussion revolves around the conditions under which a nonconservative electric field is induced, particularly in relation to changing magnetic fields and flux. Participants explore various options presented in a question, including the implications of electrical current and the geometry of the region considered.
  • Participants discuss the validity of multiple answers to the question, particularly focusing on the roles of changing magnetic fields and electrical currents. There is a debate about the interpretation of "region" and whether it can include specific geometries like loops. Some participants question the wording of the question and its implications for the answers provided.
The discussion is ongoing, with participants offering differing viewpoints on the question's design and the conditions for inducing a nonconservative electric field. Some participants suggest that the question is poorly formulated, while others explore specific scenarios to justify their interpretations.
There are noted ambiguities in the question's wording, particularly regarding the definitions of regions and the assumptions about the presence of currents and magnetic fields. Participants also highlight the lack of clarity on whether changing flux can exist without a corresponding nonconservative electric field.
dainceptionman_02
Thread moved from the technical forums to the schoolwork forums
TL;DR Summary: A (nonconservative electric field is induced in any region in which)
A. there is a changing magnetic flux
B. there is a changing magnetic field
C. the inductive time constant is large
D. the electrical resistance is small
E. there is electrical current
there can be more than one answer
I put A and B, but the answer was B, only when there is a changing magnetic field. i re-read the section and it only mentions a changing magnetic field, but not a change in flux, however, the equation states ∫E⋅ds=-dΦ/dt, which is the change in flux, so can't it be both?
I'd say you are right.
If the answer is supposed to be only (B), then I would say that this is not a well-designed question. The answer could also be (E), "there is electrical current." The current generates a magnetic field and if the current is changing (we are not told that it isn't), then there would be a changing magnetic field and hence a non-conservative electric field in the region.
Can I take the "region" to be the area enclosed by a plastic loop? :oldsmile:
Rotate the loop in a time-independent magnetic field. The changing magnetic flux through this "region" does not induce a nonconservative electric field.
I agree that there are semantic ambiguities with the wording of the question.
but changing the area or rotating the loop does induce a voltage therefore it should induce an electric field? there is the statement that a changing magnetic field induces an electric field, but couldn't an electric field also be induced by changing the area or angle, aka magnetic flux?
whoops, i just noticed the question states a region, but not in a conducting loop or geometry.
I don't think that this works as a counterexample. The existence of a non-conservative electric field should not depend on whether there are charges free to move in the loop that is rotating.
The reason I chose a plastic loop was to avoid having any induced current in the rotating loop. If the loop were a conductor, then the current induced in the loop would generate its own B field and this field would be changing with time. This time-dependent B field would induce a nonconservative E field.
I was thinking that if the loop is plastic, then we would not get an induced current. So there wouldn't be an induced, nonconservative E field in this case.
But there would be a time-dependent induced emf in the plastic loop: $$ \rm {emf} =\oint_{\rm loop} \left( \mathbf{v} \times \mathbf{B} \right) \cdot \mathbf{dl} $$ where ##\mathbf{v}## is the velocity of the loop element ##\mathbf{dl}## and ##\mathbf{B}## is the uniform, time-independent field in which the loop is rotating. So, the induced emf would not involve a nonconservative E field.
I was trying to find a justification for not allowing choice A to be a correct answer.
I think that this is a poorly formulated question and that we should leave it at that. Within the formulation as presented, I can think of a justification for not allowing choice (B) to be the correct answer. If the region of space contains a static magnetic field that is non-uniform, then the field is "changing" in that region, yet there is no induced non-conservative electric field.
Might I comment on this: I think the induced EMF, i.e. the E field from it, is in general non-conservative, because ## \nabla \times E=-\dot{B} ## is non-zero. Thereby ## \oint E \cdot dl =-\dot{\Phi} ## is non-zero.
I'm not sure what scenario you have in mind. I was trying to come up with a scenario where ##\dot{\Phi} \neq 0##, but ##\large \frac{ \partial \mathbf{B}}{\partial t} = 0##. So, in this case, ##\nabla \times \mathbf{E} = 0## and ##\mathbf{E}## would be conservative.
The formula ## \oint E \cdot dl =-\dot{\Phi} ## does not generally hold in "motional emf" scenarios, such as the rotating loop example.
The relation ## \nabla \times \mathbf{E}=-\frac{ \partial \mathbf{B}}{\partial t} ## implies ##\oint \mathbf{E} \cdot \mathbf{dl} =-\int \frac{\partial \mathbf{B}}{\partial t} \cdot \mathbf{dA}. \,\,## But ##\int \frac{\partial \mathbf{B}}{\partial t} \cdot \mathbf{dA}## does not always reduce to ##\dot{\Phi} ##.
Move a loop of fixed shape and orientation through a nonuniform, time-independent B field such that the movement causes ##\Phi## through the loop to change with time. Here, ## \oint E \cdot dl =0## since ##\large \frac{ \partial \mathbf{B}}{\partial t} = 0##. So, we can have a changing magnetic flux through the loop without the existence of a nonconservative E field. The rotating loop in a uniform, time-independent B field is a similar example.
This is very bad terminology IMHO, for reasons we have talked about before.
I don'tthink so If you look at the inference in the question (E) is not an answer.
There is not an induced E field in every region where there is a current. (E) is incorrect.
I believe the answer (A) is incorrect because there can be changing flux through a region whose shape is changing
Not my favorite question however
