What force acted on the bullet while it was moving down the barrel?
  • Thread starter Thread starter lch20yy
    Bullet
The discussion focuses on the forces acting on a bullet as it travels down a pistol barrel. A 3-gram bullet is fired at a speed of 400 m/s from a barrel length of 13 cm. The average force acting on the bullet can be calculated using the kinetic energy formula, where the energy imparted to the bullet is greater than the simple kinetic energy due to additional factors like barrel drag and gas expansion. The force of the expanding gases is not constant and varies, opposing the drag force from the barrel's rifling, which affects the bullet's rotation and energy transfer.
  • Understanding of Newton's laws of motion
  • Familiarity with kinetic energy calculations
  • Knowledge of gas dynamics in firearms
  • Basic principles of rifling in barrels
  • Calculate the average force on a bullet using the formula F = Δp/Δt
  • Explore the effects of barrel length on bullet velocity and energy
  • Study the relationship between gas expansion and bullet acceleration
  • Investigate the impact of rifling on bullet stability and accuracy
Physics students, firearms enthusiasts, and anyone interested in the mechanics of projectile motion and energy transfer in firearms.
lch20yy
a pistol fires a 3-g bullet with a speed of 400 m/s. the pistol barrel is 13 cm long.(a) how much energy is given to the bullet? (b) what average force acted on the bullet while it was moving down the barrel? (c) was this force equal in magnitude to the force of the expanding gases on the bullet?
i have solved a and b. i don't really know how to explain c, does it have anything to do with Newton's third law
Although we often talk about the average force on the bullet as it moves down the barrel, in reality the force varies. It is zero as the propellant ignites - increases to a maximum as the pressure develops, then reduces as the gas expands into the growing space behind the bullet.
Also, the force of the expanding gases - even if constant - would be, to some extent, opposed by the drag force of the barrel on the bullet - as shown by the spinning of the bullet created by the rifling of the barrel - always assuming Pistols have the spiral grooves in them. never actually seen a pistol close up.
Most hand held firearms have rifling that provides 1 rotation of the projectile for every 16inches of barrel length, pistols included. Therefore the kinetic energy imparted to the projectile is greater than the .5mv^2 due to the .5Iw^2.
Some of the energy of the burning propellent is spent propelling itself out of the barrel. With a pistol, say a .45, a typical fully jacketed projectile is around 230 grains (7000 grains in a pound). The powder charge is anywhere from 5 to 10 grains depending on the powder selected.
  • · Replies 28 ·
9K
