A problem involving Force in terms of time?
  • Thread starter Thread starter kalpeshk2011
    Force Terms Time
7 replies · 2K views
kalpeshk2011
There is a body of 3 kg which is moving to the right with a velocity of 10 m/s. A force of 6 N/s2t2 is applied on the body to the left. How much distane will the body have traveled from t=0 when its velocity is 0 m/s?
I think they should be F=ma , dv/dt = a, ds/dt = v
F=6t2
So by Newton's second law,
F=3(2t2)=ma
so i got a = 2t2
Integrating this, i got v=t3+C and s=t4/4
Now i thought initial velocity will be -10m/s which i put in C
and V=0
so, 0 = t3-10 or t=2.31 seconds
I have no clue what to do after this. I thought i'll substitute the value of t in the equation with s in it, but some how i don't think its correct. And i don't have any answers to check my solution. please help..
Hint:
Equation for s has to be written in a different form. With constant acceleration it is
s = V0t+.5at^2
You do not have constant acceleration.
How about something like this
s = V0 * t + integral(a(t) * t)*dt
where a(t) is the acceleration, F(t)/m.
You have a mistake below for your time
"Integrating this, i got v=t^3"
Your equation s=t^4/4 is incorrect because your previous integration was incorrect.
But all this mathematics and integration in physics often confuses me. I don't know when to use which technique of integration. Moreover, I have only done the rudiments of calculus. Is there any definite way to know when to use which technique?
You can use whichever you feel the most comfortable. If you had solved for the time you could use definite integrals and avoid constants of integration.
When you integrate x^n you get (x^(n+1))/(n+1). Does this help?
And when you integrate
a*x^n you get a*(x^(n+1))/(n+1) where a is a constant. Do you see your mistake now?
