A problem on quadratic equations .
33 replies · 5K views
sankalpmittal
There are 2 beakers P and Q. P contains 50 litres of water and Q contains 40 litres of acid. x litres is taken from both the beakers, mixed and replaced. This process is repeated 2 times and after the second time, there is 71/8 litres of acid in P. What is the quantity of x ?
Form the equation in the form of ax2 + bx + c = 0 where a is not equal to 0 and a,b and c are constants.
What does it mean by: "... x litres is taken from both the beakers, mixed and replaced."
What is replaced? ... By what is it replaced?
Just checking, this reads as though the mixing is done three times in all - done once then repeated twice. Is that what is meant, or should it merely have stated "This process is done twice".
I suggest you choose a couple of values for x and see what is happening , to get a feel for the situation.
For example, what happens if the samples are 5 litres from each? 10 litres from each instead.
eg: when x is 10 the first process will transfer 5 litres of acid to the water and 5 litres of water to the acid, 1st repeat will transfer less than 5 litres to each, and so on.
Sounds very much like half the mix is put back in each bucket, so that there is 50 and 40 litres of liquid in each bucket after each sample, mix and replacement
DETAILED EXPLANATION OF QUADRATIC EQUATION PROBLEM1. Suppose there is a beaker P. It contains 50 litres of water .
2. Also suppose there is beaker Q. It contains 40 litres of acid. Got it ?
3. Now "x" litres of acid is taken from beaker Q .
4. "x" litres of water is also taken from beaker P.
5. This x litres of water from beaker P and also the x litres of acid from beaker Q are mixed with each other. Got this statement ?
6. After they are mixed and form mixture , the same x litres are taken from mixed mixture and added to both the beakers P and Q.
7. Now this process from step 3 to 6 is repeated again .
8. Now the question asks what is the value of x ? How many litres ?I hope you get it . Please solve it .
Thanks in advance .
(I am 14 years , in class 10th . The above problem was from book "elementary algebra" by H.S. Hall and Knight . )
OK, let's try one iteration of removal and replacement.
If x litres is removed from the acid container, how much is placed into the water container?
umm umm:confused:
x litres removed from acid container ?? How much placed ?? :confused::confused:
I don't know where to start . Please solve it step by step .
Remove x litres from Q. Add it to x litres from P. Mix. Replace x litres into P. How much acid is there in P?
x litres from Q mixed with x litres from P becomes 2x , it is diffused uniformly .
Now x litres put back to Q , so
40 l of acid + x/2 l of water - x/2 l of acid .In P :
50 l of water - x/2 l of water + x/2 l of acid .
Right ? :confused:
That's not , what the question says ? Check my post #5 .
I am already at step 6.
Sorry my bad . I edited the post .
So if there is 40- (x/2) litres of acid in Q, what is its concentration?
No idea . I can't solve this problem . :confused:Maybe you can .
In Q :
We're here to help you solve problems. According to the rules of this site, we're not supposed to solve them for you.
See post #5 . Question corrected to extent .
In Q :
In P :
After this what ?
Can you define concentration?
So there is x/2 l of acid in P and 40-x/2 l acid in Q after the first step. You take out x litres from both bakers again. How much acid is in the x litres taken from P and how much acid is in the x litres taken from Q?
ehild
ehild
Umm :confused:
we again take out x l from both . So in
P:
How will I form quadratic equation ? I don't know . Please just suggest only one step so that i can get it . :confused:
The quadratic comes at the end. Answer my question. There is x/2 l of acid in 50 l mixture. You take x litres again. How much acid is in that x litres?
If it is easier with number, let be 5 l acid in 50 l mixture. You take out 10 l. How much acid is in that 10 litres?
ehild
In Q :
In P :
After this what ?
Try some actual numbers [ and hopefully not happen upon the correct answer ] just to see how it works. To dive straight into x is really quite advanced - especially if this is the first such problem you have done.
For example let the sample be 40 litres from each - all of the smaller [acid] container. [ie x = 40]
After mixing and replacing, you now have 20 litres of acid in each.
The 40 litre container is 20 litres of water plus 20 litres of acid, the 50 litre beaker is 30 / 20.
Now you again take 40 litres from each [1st repeat]
You get 20 lites of water plus 20 litres of acid from the 40l beaker [everything again] and 40l from the 50 litre pot which is 60% water / 40% acid so 24 litres of water - 16 litres of acid.
mix together and the 80 litres is 44 litres water - 36 litres acid
So you now return 22l water - 18l acid to each beaker
The 50 litre beaker already had the remaining 6 l water and 4 l acid to make a new mix of 28 l water and 22 l acid. The 40 litre container is just re-filled with the 22-18 mix.
Now you do it again - you calculate this time.
You will then end up with a certain amount of acid /water in each beaker.
If you keep track of what has been happening to the original 40, you can then do those same things to the general sample size, x.
For example, after the first sample - mix - replace cycle, there is x/2 litres of acid in the water and x/2 litres of water in the acid.
Work through a couple of times with numbers if necessary, and you should see how this works. For example let x = 6,10,14 or 22 - each of those is 2 times a prime. We know we are going to halve the first time, so we may as well choose an even number to make that work. From there on you will be doing something to a prime number, so should be able to keep track of what is happening.
[For example if we chose 8, it would become 4 after the first operation. If it became 2 after the second, we wouldn't know if it had been halved or "square rooted"]
Peter
Peter
Hmm a bit complicated though !
ehild
Ummmm :confused:
50 l -> x/2 l of acid
so x l -> x2/100 l of acid ?
:confused:
Ummmm :confused:
:confused:
Why are you confused? It is right. Let's go ahead.
1. How much acid remained in beaker P?
2. What is the amount of acid in the x l sample taken from the 40 l beaker?
3. You mix the two x l samples and halve the mixture. What is the amount of acid in one sample?
4. You return that x l of mixture to beaker P. How much will be the acid in it altogether in terms of x?
But the amount of acid is given after the second step: it is 71/8 l. So you have the equation for x.
ehild
ehild
In beaker Q :
40 l -> 40-x/2 l
x l -> (80x-x2)/80 l of acid
we mix those two :
x2/100 + 80x-x2/80
In one sample therefore :
(4x2+400x-5x2)/200 l of acid .
=(400x-x2)/200 l of acid .
Now ?
:frown::confused:
Do not be so desperate! You do it very well... :cool: Just some little mistake: the acid content in the new x l sample is x2/100 + (80x-x2)/80. Do not forget the parentheses! And they add up to (400x-x2)/400 in the 2x l sample. Taking the half,
one sample contains (400x-x2)/800 l acid. You add it to beaker P. But remember: when taken out x l from it, you removed x2/100 l acid. So the acid content will be the present amount + the acid content of the sample. How much is it?
ehild
sankalpmittal said:
In beaker Q :
40 l -> 40-x/2 l
we mix those two :
x2/100 + 80x-x2/80
Now ?
:frown::confused:
"sankalpmittal" when this tread is read from post #1 to the end, you are not solving anything.
I would advise no further help from anyone until a full - even if incorrect - solution is offered by OP and not just a lot of frown/confused emoticons.
PeterO,
I lead Sankalpmittal through the problem by asking questions and him answering them, almost correctly up to now. He is 14 years old, someone has to show him once how to solve such problems. Let me do it in peace. Please, do not discourage him. This is not a simple problem, you can not expect somebody at his age to solve it by himself.
ehild
ehild said:
PeterO,
ehild
Even my school math teacher failed to solve this question. He doesn't even tried it and said that this question is weird and I can't solve it . I asked 3 or 4 high school level teachers , they can't solve it . I am trying in my copy . These questions from Hall and Knight book are rather difficult not like normal text school book questions . ehild please solve it once so that I can understand its technique of solving .
Sankalpmittal, you were almost at the end. You should not have given up.
Well, you determined correctly the amount of acid both in P and in Q after the first step of mixing. Taken out x l from both beakers and mixed, then returned x l back to each beakers, the amount of acid was x/2 l in P and 40-x/2 l in Q.
In the next step, x l is removed again from both bakers. The sample from P contains x2/100 l acid, and that from Q contains (40-x/2)x/40=(80x-x2)/80 l acid. The two samples altogether contain
x2/100+ (80x-x2)80= (400-x2)/400 l acid.
This mixture is halved and one half is returned to beaker P, the other to Beaker Q. The amount of acid in each half is
(400-x2)/800 l.
(You were here, making only a little mistake.)
As x2/100 l acid has been removed from beaker P at the beginning of the second mixing step, it contains
(x/2-x2/100) l
acid in the (50-x) l solution. Now x l mixture is returned, with (400x-x2)/800 l acid content. So the total amount of acid becomes
[tex]x/2-x^2/100+(400x-x^2)/800=\frac{400x-8x^2+400x-x^2}{800}=\frac{800x-9x^2}{800}[/tex].
This amount is given in the problem, it is 71/8 l.
So your quadratic equation is
[tex]\frac{800x-9x^2}{800}=\frac{71}{8}[/tex]
Can you continue from here? Have you learned solving quadratic equations?
You will get two roots, but one is physically meaningless. Let me see what you get for x. I am not allowed to give full solution.
ehild.
In Q :
In P :
After this what ?
Answer this: how do you *know* that after the first mixing we are putting back x/2 l of acid and x/2 l of water in each vat? In other words, if we mix x l of water and x l of acid to get 2x l of mixture, how do we know that x l of the mix has x/2 l of acid and x/2 l of water? If you can answer that, you should be able to similarly decide how much acid there is in x l of a mixture from (40 - x/2) of water and x/2 of acid, etc.
RGV
ehild said:
PeterO,
ehild
You could have supplied a clear/concise solution to "similar" problem with different sized beakers as a guide to how such a question is solved.
Yes, ehild could have approached this in anyone of many ways. He chose to try to lead sankalpmittal through the problem in such a way so that sankalpmittal might actually discover some of the steps himself.
Frankly, I admire the patience shown by ehild in this endeavor.
