A problem on triangle and it's perpendicular bisectors.
6 replies · 4K views · last reply
agoogler
I'm trying to solve the following problem :
In △ABC, coordinates of B are (−3,3). Equation of the perpendicular bisector of side AB is 2x+y−7=0. Equation of the perpendicular bisector of side BC is 3x−y−3=0. Mid point of side AC is E(11/2,7/2). Find AC2.
Triangle ABC with vertices A at top, B at lower left (-3,3) and C at lower right. Perpendicular bisector lines drawn through midpoints of AB and BC, meeting at O(2,3); labelled y=-2x+7, y=3x-3, and E(11/2,7/2) at midpoint of AC.
By solving 3x−y−3=0 and 2x+y−7=0 I find that the intersection of perpendicular bisectors is at (2,3) .
Then using the two points (2,3) and (11/2,7/2), I get the equation of perpendicular bisector of AC as y=x/7+19/7.
So the slope of AC is -7 and then using point slope form , y−7/2=−7(x−11/2) Thus the equation of line AC is y=42−7x .
Similarly equation of line BC is y=2−x/3 .
So AC and BC intersect at (6,0).
By using the fact that E is the midpoint of AC, I find Co-ordinates of A as (5,7).
So the distance between A and C is 5√2, and AC2=50.
But this answer is wrong and the correct answer is 74 ( I checked the answer sheet) .
What have I done wrong ?
I don't know what went wrong before but here is a slightly different method.
Step 1. Find A using B and the gradient of AB.
Step 2. Find AC^2
I forget about E, E means only A is required.
Step 2. Find AC^2
I don't understand. How can I find AC2 after finding gradient of AB ?
Your goal is to find A and then AC^2. To find A, find the midpoint of AB then use the midpoint formula.
I agree with your answer, through a slightly different route.
O is the circumcentre, so OC=OB = 5. OE2 = 25/2, so CE2 = 25/2 by Pythagoras.
I tried and got A as (5,7) . Is that right?
Then I get C as (6,0) so AC2=50.
It must be right, you found the same answer by two different methods and Haruspex found it by a third method. There must have been no mistake originally.
