A question about how vector direction affects equations
  • Thread starter Thread starter sebastian tindall
    Direction Vector
The discussion centers on the calculation of the area of a triangle defined by vertices A, B, and C with position vectors a, b, and c. The correct formula for the area is established as 1/2|b×c + c×a + a×b|. The confusion arises from the use of vector multiplication, specifically the cross product, and the handling of negative signs in vector equations. The participants clarify the importance of using standard notation for vector operations to avoid misunderstandings.
  • Understanding of vector operations in R3, specifically cross product and dot product.
  • Familiarity with the concept of modulus in mathematical expressions.
  • Knowledge of triangle area calculation using vectors.
  • Proficiency in mathematical notation for vectors, including standard symbols for operations.
  • Review the properties of the cross product in vector mathematics.
  • Study the geometric interpretation of vector operations in R3.
  • Learn about the implications of negative signs in vector equations.
  • Explore examples of calculating areas of polygons using vector methods.
Students and educators in mathematics, particularly those focusing on vector calculus and geometry, as well as anyone seeking to clarify vector operations and their applications in area calculations.
sebastian tindall
New member warned that the homework template must be used
Hi there,
I have a very basic maths problem that has highlighted a hole in my knowledge. I was answering the following question:
The vertices of a triangle are A, B, C, with position vectors a, b, c . Show that the area of the triangle ABC is 1/2|b×c+c×a+a×b|.
and got the answer as 1/2|(a*c) + (-a*b) + (-b*c)|
I know that a*c = -c*a
but that would mean when I attempt to get the answer given in the question by switching the letters so it reads:
1/2|(-c*a) + (-a*b) + (-b*c)| i have a load of minus values in there? because I'm taking the modulus shown by the | on either side, does this mean I can just ignore the minus signs?
cheers for your help!
seb
sebastian tindall said:
Hi there,
Presumably you mean a X c = -c X a, and similar for the area formula you show. There are three different kinds of multiplication for vectors in R3: the cross product (denoted with X), the dot product (denoted with ##\cdot##), and multiplication of a vector by a scalar, as in ##c\vec{v}##. To avoid confusion in readers, use the standard notation for the cross product.
I don't think so. Since all your vector products point in the opposite direction, as compared to the answer you showed above, I suspect that you did something wrong in your calculation. Please show how you got this result.
  • · Replies 23 ·
