Does Increasing Current Add Resistance in an Inductor?
The discussion centers on the relationship between current, resistance, and inductance in inductors, specifically addressing why increasing current leads to increased resistance, or impedance. It is established that the induced magnetic field in an inductor, which is dependent on the current, creates a potential that opposes the current due to Lenz's law. The conversation also clarifies that while a solenoid without a ferromagnetic core has some inductance, it is significantly lower than that of an iron-cored solenoid, which enhances magnetic field conduction and opposing potential.
  • Understanding of Lenz's Law and its implications in electromagnetic induction
  • Familiarity with the concept of impedance in AC circuits
  • Knowledge of magnetic fields and their behavior in inductors
  • Basic principles of energy conservation in electrical systems
  • Study the principles of electromagnetic induction in detail, focusing on Lenz's Law
  • Explore the concept of impedance in AC circuits and its calculation
  • Investigate the role of ferromagnetic materials in enhancing inductance
  • Learn about solenoid design and its applications in electrical engineering
Electrical engineers, physics students, and anyone interested in understanding the principles of inductance and impedance in electrical circuits.
kostoglotov
I understand why slowing the current, causing a decrease in the flux, momentarily increases the current (stabilizing). I can use the right hand rule and Lenz's law to picture what is happening in that case.
But why does increasing the current add resistance? The induced magnetic field is dependent on the current, so adding current should just add flux in the existing direction, shouldn't it? Or is it that an inductor requires a ferromagnetic core, and this develops its own magnetic field, separate from the magnetic field produced by the current, and it is the core's field that wants to remain stable? Will a solenoid without a ferromagnetic core behave like an inductor? Even marginally?
If you try to increase the current in a conductor, it has to build a bigger magnetic field, which will contain more stored energy, and you have to supply this energy. The energy is supplied because you have to push harder (increase the voltage) to increase the current. When you try to reduce the current, energy stored in the magnetic field is given back to you as electrical energy.
In answer to your last question, a solenoid without an iron core has a small inductance, as does a straight wire, but iron cored solenoids have very large inductance.
Why does increasing the current add resistance?
You are correct the strength of the magnetic field increases with the current. But since the current is sinusoidal the magnetic field is not static. Therefore the inductor is now subjected to a strengthened and moving magnetic field which therefore induces a potential which opposes the current that produced the magnetic field. The resistance (the correct word is impedance) is therefore increased, due to higher induced potential, opposing the current.
Now the real question is therefore why does the magnetic field induces a potential which opposes the current? Now this is pure conservation of energy. Imagine if the resultant potential was actually aiding the current it would produce a stronger magnetic field and that in turn would produce more potential and more current and still stronger magnetic field. Essentially we could create a perpetual machine.
HTH
As far as ferromagnetic core is concerned, magnetic field conduction is better in such a medium than air. Therefore the ferromagnetic core causes higher opposing potential.
  • · Replies 42 ·
  • · Replies 27 ·
17K
  • · Replies 24 ·
