Acceleration in Kinematics: How Does it Vary with Displacement?
  • Thread starter Thread starter ritik.dutta3
The discussion centers on determining how acceleration varies with displacement for a particle described by the equation x = sqrt(at + 2bt + c). Participants express confusion over the problem's clarity and seek guidance on solving it. The solution involves taking the second derivative of the position function to find acceleration and using the chain rule to relate acceleration to displacement. A suggested method includes calculating dz/dx by deriving dz/dt and dx/dt, followed by substituting x back into the final result. The conversation emphasizes the importance of correctly interpreting the problem and applying calculus techniques.
ritik.dutta3
A particle moves along a straight line such that its displacement x changes with time t as x= sqrt( at+2bt + c) where a, b and c are constants, then the acceleration varies with x as
I can't figure out how do i solve it. Using graphs as well, I could not arrive at any conclusion.
The question is incomplete. Please post the full question
No, @adjacent, the question isn't incomplete. We have to fill in the blank. "the acceleration varies with x as ________ ". Sorry for not mentioning it clearly!
When you are given the position as a function of time, how do you find the acceleration using derivative?
My suggestion:
First take second derivative of x with respect to t to get acceleration which we will call z.
Then use dz/dx = (dz/dt)/(dx/dt)
Looks messy, but technically correct. In the final result, substitute for x where it appears.
  • · Replies 16 ·
  • · Replies 20 ·
