Proving (x,x) = 0 implies x = 0 in real vector space V
  • Context: Undergrad
  • Thread starter Thread starter steenis
    Linear algebra
The discussion centers on proving that in a real vector space \( V \) with a real-valued inner product \( (,) \), if \( (x,x) = 0 \), then \( x = 0 \). The participants confirm that the inner product is a symmetric bilinear map that is non-degenerate and satisfies \( (v,v) \geq 0 \) for all \( v \in V \). The conclusion drawn is that degeneracy in the bilinear map is equivalent to having a non-zero vector \( x \) such that \( (x,x) = 0 \), thus establishing the proof.
  • Understanding of real vector spaces and their properties
  • Familiarity with inner products and bilinear maps
  • Knowledge of non-degeneracy in mathematical contexts
  • Basic concepts of quadratic functions and their minima
  • Study the properties of symmetric bilinear maps in linear algebra
  • Learn about the Cauchy-Schwartz inequality and its proofs
  • Explore the concept of non-degenerate bilinear forms in vector spaces
  • Investigate techniques for proving statements involving inner products and quadratic forms
Mathematicians, students of linear algebra, and anyone interested in the properties of inner products and vector spaces will benefit from this discussion.
steenis
TL;DR
A semidefinite inner product is also positive-definite
I have the followinq question:
Let ##(,)## be a real-valued inner product on a real vector space ##V##. That is, ##(,)## is a symmetric bilinear map ##(,):V \times V \rightarrow \mathbb{R}## that is non-degenerate
Suppose, for all ##v \in V## we have ##(v,v) \geq 0##
Now I want to prove that if ##(x,x)=0## then ##x=0## for ##x \in V##
Can anybody help me ?
steenis said:
Summary:: A semidefinite inner product is also positive-definite
Apart from ##(v,v) \geq 0##, what other properties does ##(,)## have?
It is a symmetric bilinear map ##(,):V \times V \rightarrow \mathbb{R}## that is non-degenerate
Would it not be useful to translate those words into mathematical form?
By the way, the ethos on this site is to get you to do as much of the work yourself.
I think the words "symmetric", "bilinear", "map" , "##V \times V##", "##\mathbb{R}##", etc., are all mathematical terms, well known in linear algebra. So I do not know how to translate those mathematical words into "mathematical form."
A proof usually requires definitions to be translated into something that can be manipulated. For example: to prove that the square of every even number is an even number, you would translate "even number" into ##n##, such that ##n = 2k## for some integer ##k##.
That's what I mean by mathematical form.
Well, in this case it is given that "##(v,v) \geq 0## for all ##v \in V##". My question is, can anybpdy manipulate this statement into "if ##(x,x)=0## then ##x=0##, for ##x \in V##". In this context, ##(,)## is a symmetric bilinear map that is non-degenerate
As I said, the ethos on this site is that you at least make some effort to produce a proof. The logic is that you should be able to make a start at least.
So try this. Let ##x \in V## such that ##x \neq 0## and ##(x,x)=0##. The there must be a ##w \in V## with ##(v,w) \neq 0## otherwise ##x=0##, because ##(,)## is non-degenerate. And here I am stuck Can anybody finish this ?
I think the trick is to start looking at things like ##(x + ay, x + ay)##, for any ##a \in \mathbb R## and ##y \in V##.
Try to show that ##(x, x) = 0## implies ##\forall y: \ (x, y) = 0##. Which is equivalent to denegeracy.
No, one step too far for me. I do not see it ...
If you expand ##(x + ay, x + ay)##, remembering that that is always ##\ge 0##, then you get an inequality that holds for all real numbers ##a##. The trick is to show that is impossible. Try that step.
Expanding ##(x+ay,x+ay) \geq 0## results in ##a{^2} (y,y)+2a(x,y) \geq 0##, Substituting ##a=(x,y) \ne 0## gives
##(x,y)^2 (y,y)+2(x,y)^2 \geq 0##, so ##(y,y) \geq -2##. here I am stuck again
What about ##a = -(x, y)##?
That results in ##(y,y) \geq 2##, that doesnot make it more clear
That's essentially the contradiction you were looking for. ##y## was just some vector that had non-zero "inner product" with ##x##. You can scale ##y## down arbitraily.
If you go through the proof, you might see where you can tweak it to make things clearer.
Also, I think you need to get the proof formalised with all the logic and assumptions straight.
Let me show you a neat trick was to use some elementary calculus:
You had ##a{^2} (y,y)+2a(x,y) \geq 0##. Now if we define a function ##f(a) = a{^2} (y,y)+2a(x,y)##, we can find its minimum and show that is less than ##0##. This technique is useful and can be used to prove the Cauchy-Schwartz inequality. Note that for given ##x, y##, ##f(a)## is a regular real-valued function.
And, of course, the minimum value of ##a## is quite informative.
not ready
steenis said:
not ready
You must be able to find the minimum of a quadratic function!
There is an extremum at ##a=\frac {-(x,y)} {(y,y)}## which has to be a minimum. The value of ##f## at ##a## is ##-(x,y)^2(y,y)## which is always smaller than 0. You can give me the last step, please
Unless ##(x, y) = 0##, that contradicts that ##(x + ay, x+ay) \ge 0##.
To summarise: what you've shown is that ##(x, x) = 0## implies ##\forall y \in V: \ (x, y) = 0##, hence ##x## maps to the zero functional and the bilinear map is degenerate, unless ##x = 0##. In other words, degeneracy is equivalent to having a non-zero ##x## with ##(x, x) = 0##. Which is what you had to prove.
Thank you very much. Do you have a reference ?
I haven't seen this precise proof before. But, if you look for proofs of the Cauchy-Schwartz inequality you'll find a few techniques for these sorts of problems.
  • · Replies 23 ·
