A question regarding efficiency of pulleys
  • Thread starter Thread starter Nikola Tesla
    Efficiency Pulleys
The efficiency of a pulley system is influenced by the number of pulleys used, with friction being a critical factor. A single pulley can achieve a mechanical advantage of 2, while a system with four pulleys can achieve a mechanical advantage of 4. However, the overall efficiency of any pulley system is always less than one due to friction and potential rope deformation. Ignoring friction is not feasible, as it significantly impacts the efficiency of the system.
  • Understanding of mechanical advantage in simple machines
  • Basic knowledge of friction and its effects on efficiency
  • Familiarity with pulley systems and their configurations
  • Concept of energy loss due to deformation in materials
  • Research the impact of friction on mechanical systems
  • Explore methods to calculate mechanical advantage in pulley systems
  • Investigate the effects of rope deformation on pulley efficiency
  • Learn about different types of bearings and their influence on pulley performance
Engineers, physics students, and anyone interested in mechanical systems and efficiency optimization in pulley designs.
Nikola Tesla
Does a pulley have more efficiency if it has just one of those cirgular thingies
http://upload.wikimedia.org/wikipedia/en/8/8f/Pulley_class2.PNG
or more
http://www.kirkwood.k12.mo.us/parent_student/khs/BartinJ/four_pulley.gif
An explanation would be helpful as well.
Do you mean efficiency or mechanical advantage? The efficiency of a simple machine is the ratio of useful work to input work; real machines always have an efficiency less than one due to friction. You always lose some energy. (I would imagine that the more pulleys involved, the more friction and thus the lower the efficiency.)
Mechanical advantage is something different. It's the ratio of output force to input force. The entire point of using a pulley (in addition to changing the direction of the force) is to multiply the force. In your first example, the single pulley has a mechanical advantage of 2: If you pull with a force of 10N, the pulley exerts a force of 20N on the attached load. In your second example, the mechanical advantage is 4.
I am talking about percent efficency of output work over input work. So, are you sure that the less pulleys involved, the better efficiency? Also, let's exclude friction.
I'm not talking about Mechanical advantage, though. However, is there a way of knowing how to calculate the mechanical advantage by looking at the pulley system? I'm sort of able to do it by figuring out how many ropes the object is using, but I do not think it's a proper way of doing it. Thanks for the help.
You can't exclude friction, which is the cause of the less than perfect efficiency. Without friction, the efficiency will equal 1.
That's how I do it, just count the ropes. Ignoring friction (and the mass of the rope), the tension is the same throughout the rope.
Hmm, I see. Thanks for taking the time to answer.
Doc Al,
"...Without friction, the efficiency will equal 1."
Don't forget deformation of the rope. With good bearings, it could be the major cause for less than perfect efficiency.
Interesting. I'll have to think about that. It's not obvious to me how rope deformation affects things.
Doc Al,
Well, don't think too long!
After rethinking, I'm not sure it would make much difference. If the rope has a low k, then some work would go into pulling it tight before anything starts to move. But once the the tension in the rope becomes sufficient to lift the load, no more energy would be lost to stretching of the rope. It would still have to bend as it goes over the pulleys, but that probably doesn't amount to much.
Come to think of it, a system of pulleys with good bearings is probably pretty darn efficient!
My thoughts exactly. :wink:
  • · Replies 17 ·
16K
  • · Replies 29 ·
