Will the Projectile Hit the Falling Target?
  • Thread starter Thread starter 404
The discussion focuses on the physics problem of whether a projectile will hit a falling target when both are released simultaneously, with the projectile aimed at the target. Participants clarify that both the projectile and the target experience the same gravitational acceleration, which affects their vertical motion. The time it takes for the projectile to reach the target horizontally is constant, regardless of gravity. By equating the heights of both the projectile and the target at the time of impact, it is shown that they will indeed collide. The conversation concludes with a participant expressing understanding of the solution.
404
A really tough question
well.. for me atleast
A projectile leaves the gun at the same instant that the target is dropped from rest. Assuming that the gun is initially aimed at the target, show that the projectile will hit the target.
Any hints? I'm still trying to figure out where to start :cry:
EDIT: *though = tough
...can someone please tell me what the answer would be? So atleast I would know if I solved it right or not.
Both of their y-components are equal... The x - component of the bullet is just there to get in the way. Assuming no friction or air resistance
well, you know that the acceleration of gravity is -9.81 m/s^2 right? that has something to do with it. does it say if they start at the same height?
no, the gun is below the target, but it is aimed straight at the target.
Well, I suppose their time value would be the same as well.
well, you know that the acceleration of gravity has no effect on the horizontal component, and no matter the mass of the object, the downward acceleration will be the same for both. the velocities will be different, because of mass differences, but you can still use that information to solve it.
Yeah, I already know all the things talked about above from all the other projectile motion questions I did... I made some progress, but can someone please tell me what the answer would be? So atleast I would know if I solved it right or not...
well, unless you have specific numbers for like the velocity of the bullet, or masses, then there's no number-plugging work, obviously. this link seems to show it accurately: http://www.physicsclassroom.com/mmedia/vectors/mzf.html
if that doesn't help you, then i don't know what to do, because monkeys and bananas can solve ALL problems.
lol... thanks, I read it, but it doesn't seem to give an algebraic solution.
bump, does anyone know?
Lets say that the distance between them on the x- axis is X, and on the y-axis it is Y, the target's hight is H. The components of the projectile's initial speed are Vx and Vy, without gravity they should hit with those speeds. So the time that it takes the projectile to get to the target is X/Vx we'll call that time T. T is constant with or without gravity (as they mentioned above). With gravity we can write that the projectile's hight is:
h = Vy*t - 1/2*gt^2 and the target's hight is:
h = H - 1/2*gt^2
we know that for them to collide they have to have the same hight at time T (thats when they have the same x). we also know that Vy*T = H because without gravity they would have hit at hight H (the target woulden't have fallen, so after time T the projectile's hight is:
hp = H - 1/2*gT^2 and the target's hight is:
ht = H - 1/2*gT^2 so:
ht = hp!
Oh I see now. Thanks
