A runner inside a train, and it stops
  • Context: Undergrad
  • Thread starter Thread starter karlth
    Train
The discussion revolves around a thought experiment involving a train, a car inside the train, and a jogger running inside the car. Participants explore the relative speeds of the jogger as perceived by an outside observer when both the train and car come to a stop. The scope includes concepts of classical mechanics and frames of reference.
  • Some participants argue that the jogger's speed relative to an outside observer is 220 km/h, considering the speeds of the train and car add up.
  • Others contend that the jogger's speed should be 100 km/h relative to the outside observer, as everything inside the train moves at the same speed as the train itself.
  • A participant suggests that the question is ambiguous and could be better framed to clarify the reference frames involved.
  • Some participants mention that the scenario involves classical mechanics rather than relativistic effects, as the speeds are not high enough for significant relativistic calculations.
  • There is a discussion about the implications of frames of reference, with some asserting that the jogger's speed is dependent on the observer's position.
  • Several participants express confusion about the setup of the thought experiment, particularly regarding the feasibility of running inside a car.
Participants do not reach a consensus on the correct speed of the jogger relative to an outside observer, with multiple competing views remaining on the interpretation of the scenario.
Some participants note that the speeds involved are not high enough to invoke relativistic effects, suggesting that the discussion is primarily within the realm of classical mechanics. There is also mention of potential ambiguity in the framing of the question regarding reference frames.
karlth
This concerns a debate I'm having with two friends of mine, hope someone here can help.
You have a train traveling at 100km/h. Inside the train there is a car traveling at 100km/h. Inside the car is a jogger running at 20km/h.
Suddenly the train and car stop and the jogger is thrown forward out of the train and car. At what speed relative to an outside observer?
100? 200? 220?
(We are Computer Scientists hence our lack of understanding :) )
Each aspect is a different system. The train itself and then the car. Inside the car the runner is going at 20km/hr. Inside the train the runner is going 100km/hr regardless of how fast he's running because the car is a lone system. Since the train is traveling at 100km/hr everythig inside the train is traveling at the same speed with repesct to the observer outside. So your answer is 100km/hr.
(If the observer was in the train it would be 100km/hr and if the observer was in the car with the runner it would only be 20km/hr. Everrything depends on the system the observer is viewing.)
BTW, this question is General Relativity. You could repost this in that section if you would like more responses.
Please reread. The jogger is INSIDE the car.
The jogger will exit the train at 220km/h as observed from the ground.
Eehh??
this certainly involves "relativity" but not "Einsteinian" relativity, either "special" or "general". The speeds involved just aren't high enough for such effects to be measurable. This is purely "Gallilean relativity".
I am assuming that the car is moving toward the front of the train and the person is running toward the front of the car.
To a person sitting inside the car the man is running at 20 kmph. To a person standing inside the train the car is traveling at 100 kmph and the runner an additional 20 kmph: 120 kmph. To a person standing outside the train the train is doing 100 kmph the car an additional 100 kmph and the runner yet another 20 kmph: the runner is doing 220 kmph relative the the ground.
(A relativistic calculation would give that the person is running, relative to an observer in the train at (100+ 20)/(1+ (100)(20)/c2)= 119.99999999999733333333333339259 kmph. and, relative to a person on the ground, 219.99999999996800000000000497769 kmph. Of course, with the speeds given to 2 and 3 significant figures, that accuracy is meaningless. those are 120 and 220 kmph rounded to reasonable accuracy.)
You did not state at what speed relative to the train/car/person/other reference frame the outside observer is traveling at. Although for this reason, your question is slightly ambiguous, but I think we all know what you mean.
The problem is probably better stated backwards. The person is running at 20km/h relative to the car which is traveling at 100km/h relative to the train, which is traveling at 100km/h relative to reference frame A. I assume they are all traveling in the same direction so the persons speed is simply the sum of the three speeds in classical mechanics. This is 220km/h in reference frame A. When the dude is flung out, assuming no friction has slowed him down, he will still be gonig at 220km/h.
Things are slightly different in special rel where velocities are not simply summed. A good explanation of this is given by wikipedia but needless to say, at these velocities, it is basically 220km/h.
http://en.wikipedia.org/wiki/Velocity-addition_formula
Looks like someone beat me to it. In that case, what he said.
So I was wrong. :)
Thanks a lot for the informative replies. :approve:
Exactly! Therefore he can only travel as fast as the car is traveling and the car (INSIDE the train) can only travel as fast as the train is traveling.
:confused:
Your logic eludes me.
Why? The automobile is moving at 100km/h with respect to the train (obviously, it is on a very short raceway). So the speed of the automobile from the vantage point of the ground is the train's speed plus the automobile's speed within the train, for a total of 200km/h.
Same can be done between the automobile and the jogger. You sum the three velocities.
The train and car do not have to suddenly stop. As long as they are all in motion, the runner IS traveling 220km/h relative to the outside observer. This is just an exercise in frames of reference.
To the outside observer the train is traveling +100km/h, the car is traveling +200km/h, and the runner is traveling +220km/h.
To an observer sitting in the train, the outside observer is traveling -100km/h, the car is traveling +100km/h, and the runner is traveling +120km/h.
To an observer sitting in the car, the outside observer is traveling -200km/h, the train is traveling -100km/h, and the runner is traveling +20km/h.
To the runner, the outside observer is traveling -220km/h, the train is traveling -120km/h, and the car is traveling -20km/h.
I'm still trying to figure out how the hell somebody can run inside a car. I've done a few things in a car, that didn't involve running, and felt cramped.
Yes. I thought it wasn't the best setup for the thought experiment, but it will do.
My only concern was that perhaps the jogger-versus-car was what might have been confusing GetPhysical.
Possible, I suppose. I hadn't thought of that.
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 16 ·
  • · Replies 25 ·
9K
10K
11K
