What Conditions Ensure Convergence of Sequences?
  • Context: Graduate
  • Thread starter Thread starter DespotDespond
    Convergence
The discussion centers around the conditions necessary for the convergence of a sequence \( x_1, x_2, \ldots \) given that a related sequence \( y_n = f(x_n) \) converges. Participants explore the implications of continuity, invertibility, and specific properties of the function \( f \) in the context of convergence, particularly in relation to optimization algorithms.
  • One participant asks what conditions on the function \( f \) ensure that the sequence \( x_n \) converges if \( y_n \) converges.
  • Another participant suggests that continuity of \( f \) is necessary for convergence.
  • A different participant argues that continuity is not sufficient for the converse implication, providing an example where \( f(x) = x^2 \) is continuous but does not guarantee convergence of \( x_n \).
  • It is proposed that if \( f \) is invertible and the inverse is continuous, this would suffice for ensuring convergence of \( x_n \).
  • One participant expresses doubt about finding a simple condition and requests more information about the specific context of the problem.
  • A participant describes their algorithm for optimizing Markov decision processes, noting that the objective function \( f \) is strictly monotonically increasing and bounded from above, leading to the convergence of \( f(x_n) \).
  • Another participant questions whether \( f \) has special properties beyond continuity and injectivity that could be leveraged in the discussion.
Participants do not reach a consensus on the necessary conditions for convergence. There are competing views regarding the role of continuity, invertibility, and other properties of the function \( f \). The discussion remains unresolved with multiple perspectives presented.
Participants note that the function \( f \) is not injective, which complicates the conditions for convergence. There is also mention of the need for local results rather than global ones, indicating potential limitations in the applicability of certain conditions.
This discussion may be of interest to those working on convergence in sequences, particularly in the context of optimization algorithms and mathematical analysis.
DespotDespond
Hi,
I have a basic question about convergence.
I have two sequences, x1, x2, ... and y1, y2, ..., where yn = f(xn) for some function f : ℝN → ℝ.
I have shown that the sequence, y1, y2, ... converges. What conditions do I need on the function, f, to ensure that the sequence x1, x2, ... also converges?
Thanks in advance
You need the function f to be continuous.
In fact this is an equivalent definition of being continuous: f is continuous if and only if whenever x_n \to x, f(x_n) \to f(x).
But the poster is asking the converse. He's asking if ##f(x_n)\rightarrow x## implies ##x_n\rightarrow x##. So continuity is irrelevant here.
Indeed, R136a1 is correct. I want the convergence of the xn → x given the convergence of f(xn) → f(x).
In this case, continuity of f is not enough. For example, f(x) = x2 is continuous, but if we define the two series as follows
x1 = √2, x2 = -√2, x3 = √2, x4 = -√2, ...
and
y1 = 2, y2 = 2, y3 = 2, y4 = 2, ...
then yn is convergent and yn = f(xn), but xn is not convergent.
If the function, f, were invertible and the inverse was continuous, then that would be enough. Right?
The problem is that in my case I don't think that f is invertible.
I don't necessarily need the result to hold globally, i.e. for all x. A local result might suffice.
Any syggestions would be appreciated.
and
You don't even need fully invertible. Just a continuous left-inverse suffices.
I kind of doubt there is a simple condition. Could you perhaps give some more information about your specific situation?
Hi,
Thanks for the response.
The problem is related to an algorithm that I've constructed for optimising Markov decision processes. I'm trying to prove the global convergence of the algorithm. I don't want to go into any unnecessary detail, so I will try to explain as briefly as I can.
I have an objective function, f, of which the x's are the parameters I wish to optimise.
My algorithm generates a series of parameter vectors, x1, x2, ...
I've managed to show that the objective is strictly monotonically increasing with respect to this series, i.e. that
f(x1) < f(x2) < ...
I know that f is bounded from above, so I used the monotone convergence theorem to conclude that the series
f(x1), f(x2), ...
converges.
Generally, f is not injective and so doesn't have an inverse.
Thanks for your response. But what I really wanted to know is whether ##f## has some special properties that we could use. We know it's not injective, but is there perhaps something else? Obviously, if ##f## can be any continuous function, then what you're trying to do is false. So there must be something special going on.
  • · Replies 24 ·
