A simple differential equation problem.
13 replies · 3K views
is there a solution to this euqation: (i got to in a problem in physics so the notation is appropiate):
[tex](m_1+m_2)\frac{dv}{dt}=m_1g-m_2gsin(a)-f_s-\beta v-V\rho g[/tex]
is there a solution or perhaps i got it wrong in equations?
thanks in advance.
Well, the notation might be appropriate, but your definition of the symbols is not!
Assuming that everything is constant apart from v,
just rewrite your diff. eq as:
[tex]\frac{dv}{dt}+Av=B[/tex]
where A and B are constants.
You may use an integrating factor to solve this problem.
This will also work for non-constant A and B (depending solely on t, and not on v!), but you might not get an explicit formula in terms of elementary functions then.
It is lacking. How should I know what you mean by your symbols when you don't define them?
well, the m's are masses, the angle a doesn't change with time (perhaps here lies your critic), V stands for volume and rho stand for water density.
that's it.
Hmm..and I guess that g is the acceleration due to gravity and beta is the coefficient of air resistance. But you didn't sayu that.
Furthermore f_s is some sort of applied force I don't know what is.
what integrating factor to use here?
i mean: dv/v+Adt=Bdt/v dv/v+(A-B/v)dt=0
dv/v(A+B/v)+dt=0 will that suffice here?
this is a pretty simple integrating factor
if you mmove the resistance term (Bv) to the left hand side and divide by (m1+m2) than you have an quation of the formdv/dt +Pv = Q
where Q is some function of t, and so is P
in a problem like this the integrating factor is e^(integral of P dt)
multiplying by that and simplifying will get you an equation of the formd(ve^(integral P dt))/dt =Qe^(integral P dt)
integrate, and then you'll have a simple algebra problem
also notice that the solution only has 1 parameter, all first order differential equation have only one parameter in the solution.
Why use an integrating factor? The ODE's clearly separable...
Why use separation of variables?
You can clearly use an integrating factor..:smile:
It's just a matter of preference what method you use.
hmm it doesn't appear to be seperable.
if you note its of the form dv/dt +Bv=C
as somebody else mentioned, that is not a seperable equation
So, you disagree that the diff.eq may be rewritten as:
[tex]\frac{1}{C-Bv}\frac{dv}{dt}=1[/tex] ??
