Undergrad Single Quark at Rest: The Mystery of Dark Matter?
  • Thread starter Thread starter MatthewKM
    Quark Rest
The discussion centers on the stability of quarks, emphasizing that all nucleons consist of three quark configurations due to color confinement, which prevents isolated quarks from existing. The hypothesis suggests that during the Big Bang, quarks coalesced into protons, raising questions about the fate of any single quarks that might have escaped this process. However, it is argued that single quarks cannot exist in isolation according to Quantum Chromodynamics (QCD), making inquiries about their behavior in a vacuum largely theoretical and not practically observable. The conversation also touches on the implications of quark states within the QCD Hilbert space, indicating that while such states can be mathematically defined, they cannot be realized or measured in practice. Ultimately, the discussion concludes that the concept of a single quark at rest remains an intriguing but fundamentally flawed proposition within current physics frameworks.
  • #121
No, in gauge theories gauge dependent "states" don't describe any physics. It doesn't matter whether the gauge symmetry is "higgsed" or not. It also never can be spontaneously broken!
  • #122
So how is one W-boson, or one electron, weak-SU(2) gauge invariant?
  • #124
vanhees71 said:
What's measured are S-matrix elements between physical states, which are gauge invariant.
That's misleading. An S-matrix element is a probability amplitude. As such, it can only be measured in an ensemble. A single measurement never gives you the S-matrix element. On the other hand, a single measurement detects a single electron or a single W-boson. It's not clear in what sense it's gauge-invariant under weak-SU(2) gauge transformations.
  • #125
Once more:
https://doi.org/10.1016/0550-3213(81)90448-X
Anything what's observable, including cross sections (S-matrix elements), must be gauge invariant. Gauge-dependent quantities take arbitrary values and thus don't describe unique phenomena in Nature.
  • #126
Fine, but it still doesn't explain how one electron state is gauge invariant. It must be so, but I don't see how to prove that it indeed is.
  • #128
vanhees71 said:
That's a pretty subtle question. For a thorough discussion, see the already above quoted lecture notes by Axel Maas:
https://static.uni-graz.at/fileadmin/_Persoenliche_Webseite/maas_axel/ew2021.pdf
I guess the answer to my question is something like this. Physical states are those which are annihilated by the BRST charge. A gauge transformation of a physical state, say one-electron state, adds a zero-norm state to the initial state, so it represents the same physical state. That looks fine.
But then, the same should work for QCD in deconfined phase. The one-quark state in the deconfined phase of QCD should be gauge invariant, very much like the one-electron state is gauge invariant in electro-weak gauge theory.
You are an expert for heavy ion collisions. I think such a collision can produce a deconfined phase of QCD, so maybe a one-quark state can appear in that context?
  • #129
The deconfined phase of QCD is a many-particle state, hence the phrase ''The one-quark state in the deconfined phase of QCD'' is meaningless.
Likes PeroK and vanhees71
  • #130
That's a misconception from the 1980ies. Today it's clear that the "QGP" which can be produced in heavy-ion collisions is far from being a thermal-equilibrium ideal gas of massless quarks and gluons. One rather has a strongly coupled liquid, and still there's a kind of confinement. How to really understand this state is far from being clearly resolved.
In the vacuum it's qualitatively clear: Quarks and gluons cannot be observed as asymptotic free states due to confinement. All we observe are asymptotic free color-neutral hadrons (usually baryons and mesons but also maybe more exotic tetra or maybe penta-quark states).
The difference between QCD and QFD is that the latter is not confining (not even asymptotic free).
Likes PeroK and Demystifier
  • #131
Not necessarily. For example, if a many-particle state is a simple tensor product of one-particle pure states, then we can talk of well defined one-particle pure states.
  • #132
A different phase is a different sector of states. The Hilbert space of the deconfined phase is disjoint with the Hilbert space of the vacuum sector. There is no decomposition of the states of the deconfined phase into well defined one-particle pure states.
  • #133
Instead of taking about phases of QCD, which apparently nobody understand very well, let us talk about phases of water. Ice is a "confined" phase, steam is a "deconfined" phase. I think we can talk about single molecules within steam.
  • #134
Yes. But this is because here particle number is conserved and the molecules are not quasiparticles. As a consequence, the phase transition doesn't generate a different sector unless the thermodynamic limit is taken, where the particle structure disappears.
The sector structure in relativistic QFT is quite different from that of nonrelativistic theories.
Likes dextercioby and vanhees71
  • #135
1. Since you point out that molecules are not quasiparticles, are you suggesting that some would-be analogous objects in QCD are quasiparticles? Which ones?
2. Why does particle structure disappear in the thermodynamic limit?
  • #136
The quasiparticle structure in nonrelativistic QFTs is analogous to the sector structure of relativistic theories, obtained by redefining the vacuum of the Fock space. The renormalization in relativistic QFT does the same. There the unphysical, bare particles are the Fock particles, whereas the physical, renormalized particles are what would be called quasiparticles in a nonrelativistic setting.
Because the thermodynamic limit (where the volume and the number of particles become infinite) changes the structure of the ##C^*##-algebra of observables (particle number is no longer an observable) and hence the state space. Without the thermodynamic limit one has no discontinuous phase diagrams, hence no rigorous phase transitions.
Likes Demystifier, dextercioby, gentzen and 2 others
  • #137
I see. But what if we look at all this from the the point of view of lattice QCD? The lattice is assumed to be finite, so there is no thermodynamic limit in a rigorous sense. In a regime in which it describes confinement, the bare quarks are unphysical particles, while the dressed states, like mesons and nucleons, are physical quasiparticles. But even on a finite lattice one can study phase transitions in a non-rigorous phenomenological sense. So in this sense I would expect that, at high energies/temperatures, the bare quarks become physical particles, very much like electrons in Fermi gas. Or at least, that the quarks only wear a "swimming suit", so that the physical states don't differ much from bare quarks, very much like the quasiparticles in Fermi liquids. Does it make sense to you?
  • #138
Electrons in a Fermi gas are quasiparticles, not particles. The vacuum structure of them is different from that of the bare vacuum, and the quasiparticle Fock space is disjoint from the bare particle Fock space.
If you treat everything on a finite lattice, the quasiparticles can be described in terms of the bare particles, but they are very complex bare multiparticle states. Thus the single lattice electron quasiparticle has essentially nothing to do with the single bare lattice electron.
Similarly, in lattice QCD, the unconfined lattice quarks of a quark-gluon plasma are in fact very complex bare multiquark states, and the confined lattice quarks of vacuum QCD are another class of very complex bare multiquark states of a very different nature (which is clearly revealed in the thermodynamic limit).
  • #139
Can you support it by a reference?
  • #140
Biss, H., Sobirey, L., Luick, N., Bohlen, M., Kinnunen, J. J., Bruun, G. M., ... & Moritz, H. (2022). Excitation spectrum and superfluid gap of an ultracold Fermi gas. Physical Review Letters, 128(10), 100401.
https://arxiv.org/abs/2105.09820
Likes gentzen and vanhees71
  • #141
The point is that the quasi vacuum defined by the Fermi surface depends on temperature, hence one has a different sector for each temperature. The standard vacuum corresponds to zero temperature.
  • #142
From the Introduction:
"For an interacting Fermi gas, the relevant quasiparticles are particle-hole excitations, where one particle is removed from the Fermi sea and a hole is created in its place."
That makes sense. But originally you said that electrons are quasiparticles, not that particle-hole excitations are quasiparticles.
Likes Maarten Havinga
  • #143
But in real experiments we always have a finite number of electrons confined in a finite volume. Under this condition, all sectors are unitary equivalent.
  • #144
In more physical terms, here the ground state is called ground state, and the vacuum is always the state with no particles present.
In a many-body system in thermal equilibrium often you can describe the system in terms of "quasi particles". These describe usually collective excitations of the ground state but look similar to "particles" in the Green's-function formalism, and different phases of a system are characterized by different kinds of "thermodynamically relevant quasi-particles".
E.g., in a Fermi liquid you can have a "normal phase". There you have a "ground state" which is filled up to the Fermi level, and quasi-particle-like excitations which may look like the "real particles" but with a different mass. Also holes in the Fermi sea can look like quasi particles with the opposite charges. Then you can have bound states of holes and particles ("excitons") etc. etc. Other quasi-particle-like excitations can be also of bosonic nature, e.g., phonons, plasmons, etc.
Phases are usually characterized by an order parameter. E.g., in the normal phase of a Fermi liquid, you have ##\langle \psi \psi \rangle=0## but if there is any (effective) attractive interaction between the Fermions at sufficiently low temperatures the ground state is no longer a Fermi sea but also Cooper pairing occurs, where ##\langle \psi \psi \rangle \neq 0##, and the Cooper pairs (which are pairs of two electrons close to the Fermi surface with opposite momenta and usually also opposite spin) become quasi-particles too. A specialty here is that the non-zero order parameter describes an electrically charged state (with ##q=-2e##) where the charge is the electric charge, i.e., coupling to the electromagnetic field, i.e., the symmetry under multiplication with a phase factor is a local symmetry, and thus you have no spontaneous symmetry breaking but a "hidden local gauge symmetry" aka the "Anderson-Higgs-Brout-Englert-Kibble-et-al mechanism", making the corresponding gauge field, i.e., here the photons, massive. This explains the Meisner effect.
  • #145
These are one kind of a whole zoo of quasi-particles :-).
  • #146
Which zoo is bigger, quasiparticles in condensed matter, or hadrons in particle physics? :wink:
Allegedly, there is a proof that this problem is undecidable.
  • #147
Quasiparticles may be bigger, but hadrons are nicer. :wink:
Likes Demystifier
  • #148
This is like electron-positron creation in QED. What is created is a 2-quasi-particle state in which you can identify one as the electron the other as the hole.
Yes, but the quasiparticles in different sectors are multiparticle states very different from the single-particle states at 0 temperature.
  • #149
I think there are more quasiparticles in condensed matter than hadrons in particle physics. Particularly there are more exotic ones like Weyl fermions and (maybe/maybe not) Majorana fermions, magnetic monopoles, etc. etc.
On the other hand there's also many-body physics of strongly interacting matter, and there you get also quasi particles in various QCD phases. The only problem is, it's harder to be observed. We rely on heavy-ion collisions, where you produce for a few 10 fm/c a blob of strongly interacting matter with some few 10 fm in spatial extension, and all you can observe are the hadrons in the state after thermal freeze-out and the particle abundancies which are more or less fixed at chemical freeze-out, which is close to the confinement-deconfinement transition region (for the matter created in heavy-ion collisions at the highest available energies at RHIC and LHC it's matter close to 0 net-baryon density with a cross-over pseudo-critical temperature of about 150 MeV/k). Then you have also electromagnetic probes ("dileptons" and "photons"), which are irradiated during the entire fireball evolution, which gives you a space-time averaged glimp about the spectral properties of the em. current-current correlation function providing some information on the medium modifications of the light vector mesons in the hadronic phase and their "melting" into the vector-vector correlation functions of the quarks and anti-quarks, etc. etc. Here the "quas-iparticle picture" becomes problematic since usually the "relevant excitations" have a quite large spectral width, i.e., the quasi-particle formulation of kinetic theory, derived from the full QFT non-equilibrium many-body formalism (Schwinger-Keldysh time contour -> Kadanoff Baym equations in the Wigner representation -> coarse graining to a BUU equation) becomes problematic, and you need so-called "off-shell transport" descriptions.
  • #150
In a last couple of days I was reading about a whole new line of research about IR physics, reviewed in https://arxiv.org/abs/1703.05448. In particular, it is argued that large gauge transformations can map physical states into new physically inequivalent states.
In the context of this thread, it is argued that, in the absence of confinement, quarks in a color singlet state may physically turn into a color non-singlet state. https://arxiv.org/abs/1707.08016
  • · Replies 46 ·
9K
  • · Replies 37 ·
  • · Replies 62 ·
11K
  • · Replies 20 ·
