- 14,792
- 7,438
Any comments on the extended version of my post #57?RockyMarciano said:I had the impression that you equated non-realism in the Bell context wih denying external reality.
I guess I'm one of the lucky ones that has already reached a conclusion in the choice between nonrealism and nonlocality just by discarding any theory that contemplates FTL communication. It was not that hard, I'd say most physicists agree that predictive acausal nonlocality(that is nonlocality not just as a non-falsifiable ontology allowing "FTL influences" which adds nothing to a theory) is not compatible with science, which is causal(or at the very least microcausal like QFT shows) by definition.stevendaryl said:I would put Bell in the same camp as Einstein in this regard. And I don't agree that there is a consensus that Einstein was wrong. He was certainly wrong about local hidden variables--tests of Bell's inequality show that there are no such variables. As to whether the lack of local hidden variables implies nonrealism or nonlocality, there isn't a consensus.
Demystifier said:As one possible meaning, let me copy-paste from my presentation at a conference:
1.2 Making sense of local non-reality
- One interpretation of Bell theorem: local non-reality
- Physics is local, but there is no reality.
- Does it mean that nothing really exists?
- That would be a nonsense!
Here is what it should really mean:
- Physics is not a theory of everything.
- Something of course exists, but that’s not the subject of physics.
- Physics is not about reality of nature,
it is only about what we can say about nature.
- In physics we should only talk about measurable stuff.
- It’s important to talk also about non-measurable stuff,
but just because it’s important is not a reason to call it physics.
Bell theorem ⇒ reality is non-local
- logically correct, but that is not physics
QM ⇒ signal locality
- that is measurable, so that is physics
In short, “local non-reality” should mean:
- Reality is non-local.
- Physics is about the measurable, which is local.
- In that form, local non-reality does not necessarily
need to be accepted, but at least can be reasonably debated.
RockyMarciano said:I dislike the use of the word "reality" here because even if an effort is made in your reasoning to separate non-realism from solipsism it still assumes that reality is classical
But from your description, it seems to me that rejecting Einstein's realism means accepting contextuality which isn't discussed as frequently as realism or locality, although it seems to be the more important concept.stevendaryl said:So what does it mean to reject Einstein's realism? It seems to me that it means either solipsism, or it means rejecting the idea that there are physical states.
Locality in QFT is defined as spacelike separated observables commute. Bohmian mechanics is local in that sense.RockyMarciano said:Bohmian mechanics cannot be local in the way QFT is as BM is indistingushable from NRQM, so that is already showing Norsen assertions are at odds whith what most people know.
J.S. Bell's Concept of Local CausalityRockyMarciano said:You could try and define what is the definition of locality(separated from classicality) that Bell assumed.
ShayanJ said:But from your description, it seems to me that rejecting Einstein's realism means accepting contextuality which isn't discussed as frequently as realism or locality, although it seems to be the more important concept.
...the measurement result of a quantum observable depends on the specific experimental setup being used to measure that observable
This notion of reality seems too fundamental for physics to be abandoned and its general enough to include QM too, even in the Copenhagen interpretation. So I think this is not Bell's notion of reality because he was trying to compare the classical laws of physics with the quantum laws of physics.(I mean laws that have the same familiar nature as the classical intuitive laws that we know, vs. the unintuitive laws with the same nature as QM.)stevendaryl said:For any state S, let F(M,S) be the set of possible results of measurement M in some possible future of S. The fact that r∈F(M,S) is a fact about state S. It's an "element of reality".
Measurable or measured? Spin is measurable, but is it real before it is actually measured?RockyMarciano said:defining reality as "measurable stuff"
If the current state determines uniquely the possible future states it is not compatible with nondeterminism as you define it. If it doesn't I don't think is the notion Einstein had of realism. Unless what you mean by indeterminism (that there are many possible future states compatible with the current state) in the sense of classical probabilities where the future state of a dice after tossing as determined by the actual state is compatible with 6 different results. This is not nondeterminism, this is lack of knowledge about the currrent state which is diferent and perfectly deterministic. Could you specify?stevendaryl said:Here's the way that I understood Einstein's notion of realism. He thought of the world as a succession of physical states, where the current state determines the possible future states. Note that there is no assumption of determinism here, because this notion of realism is (to me) consistent with nondeterminism. Nondeterminism would just mean that there are many possible future states consistent with the current state.
Again that set is simply an assessment about our ignorance, like in classical deterministic probabilities. Violations of BI show how misleading that assessment can be if based in classical reasoning and probabilities.The point of Einstein's "elements of reality" is this: Suppose the world is in some state [itex]S_1[/itex] where you know with certainty the value of some future measurement; you know that measurement [itex]M[/itex] will result in [itex]r[/itex]. Then if we make the non-solipsistic assumption that this prediction is revealing something about the world (as opposed to just being a prediction about future states of your own brain), then it seems that what we can conclude is that a future state [itex]S_2[/itex] is not possible if in state [itex]S_2[/itex] measurement [itex]M[/itex] has a different result than [itex]r[/itex]. In that case, the "element of reality" can be defined explicitly:
For any state [itex]S[/itex], let [itex]F(M,S)[/itex] be the set of possible results of measurement [itex]M[/itex] in some possible future of [itex]S[/itex]. The fact that [itex]r \in F(M,S)[/itex] is a fact about state [itex]S[/itex]. It's an "element of reality".
It clearly rejects states in their classical conception.So to me, Einstein's criterion for "elements of reality" just follows from the assumption that there exists a physical state, and the non-solipsistic view that the predictions of physics reveal something about the world.
I'm referring to EPR realism, Demystifier implied in his word reality, that reality meant EPR realism.stevendaryl said:What does it mean for reality to be classical or not?
I don't think this could ever have been Einstein's thoughts. Knowing relativity, it is clear that there is no objective physical meaning to a succession of physical states since different observers have different notions of succession. He thought of time as an obnoxious illusion. There would only be one timeless state - which would mean a Heisenberg picture of the universe.stevendaryl said:Here's the way that I understood Einstein's notion of realism. He thought of the world as a succession of physical states, where the current state determines the possible future states.
No. Bohmian mechanics is nonrelativistic and non-field, and its dynamics has not even a notion of spacelike separation that would be well-defined.zonde said:Locality in QFT is defined as spacelike separated observables commute. Bohmian mechanics is local in that sense.
The operators in QFT are very different mathematically from the operators in NRQM, so this is not possible.zonde said:Locality in QFT is defined as spacelike separated observables commute. Bohmian mechanics is local in that sense.
This is a definition that simply mixes locality with realism making them indistinguishable while at the same time claiming it has nothing to do with realism and erroneously endorsing it to Bell. It is terribly confused.
If by real you mean EPR real, they are not. They are physical measurements, if a physical measureent hasn't been performed yet it doesn't exist in that sense.Demystifier said:Measurable or measured? Spin is measurable, but is it real before it is actually measured?
Furthermore, suppose that we have entangled EPR pair of particles with spin. Suppose that spin of one particle is measured by Alice, and spin of another particle is measured by Bob. Suppose that Alice and Bob do not compare the results of their measurements. In this case, are both spins real?
Again.These are empty question without specifying the correlation, for instant the classical correlation is not real, as shown in experiments violating the BI.If yes, are the results of those measurements correlated?If yes again, is the correlation real?
A. Neumaier said:I don't think this could ever have been Einstein's thoughts. Knowing relativity, it is clear that there is no objective physical meaning to a succession of physical states since different observers have different notions of succession. He thought of time as an obnoxious illusion. There would only be one timeless state - which would mean a Heisenberg picture of the universe.
Demystifier said:1.2 Making sense of local non-reality
Watch out because even with the warning nothing to do with saying "nothing exists", some people might take the part about living in a subjective universe in the sense of claiming the mind or consciousness is constructing what we see, or the need of a personal observer and nonsense like "the moon is not there when you are not looking". Non-realism doesn't make a distinction between interactions that are measurements and the rest of interactions. All interactions either consciously observed or not shape the physics we ultimately get to observe.DrChinese said:So my point is that non-realism has nothing to do with saying "nothing exists". It only has to do with saying: "no initial configuration determines the observed outcome." We live in a subjective universe, and how we choose to observe actively shapes the reality we see.
DrChinese said:Examples would be dropping the requirement that A causes B when A occurs first. I.e. deny causality. You can deny determinism and hidden variables, i.e. drop the requirement that hidden variables now determine outcomes later. In virtually any entanglement setup of 2 or more particles, the time sequencing does not appear to in any way affect the statistical outcome. Neither does causal ordering in many cases.
We can choose any time-slicing we want just by exploiting the relativity of spacelike simultaneity, included those slicings that coincide with classical determinism. Non-realism in the mathematically specific QFT achieves it gets rid of any notion of spacelike simultaneity , not only absolute but relative, and this use of simultaneity is not possible anymore.stevendaryl said:But in an EPR-type situation, we can choose a time-slicing so that Alice measures spin-up along direction [itex]\hat{a}[/itex] a fraction of a second before Bob measures the spin of the corresponding particle along that axis. We know what result Bob will get ahead of time. So Bob's result in the future is determined by the state of the world right now (according to the time slicing). Bob's result is determined as soon as Alice gets her result. The facts about one time slice determine (some of) the facts about a later time slice.
"People like us, who believe in physics, know that the distinction between past, present, and future is only a stubbornly persistent illusion." - Albert Einsteinstevendaryl said:I agree that viewing spacetime as an unchanging whole is one way to think of relativity---that's the "Block Universe" idea. But was that the way Einstein thought of it?
RockyMarciano said:We can choose any time-slicing we want just by exploiting the relativity of spacelike simultaneity, included those slicings that coincide with classical determinism. Non-realism in the mathematically specific QFT achieves it gets rid of any notion of spacelike simultaneity , not only absolute but relative, and this use of simultaneity is not possible anymore.
Let me remind everyone that this is a thread about Bohmian mechanics and related foundational or philosophical issues, and not about EPR or Bell. If you want to continue the discussion of the latter, please do it in a new thread linking to here, and not in this thread!stevendaryl said:But in an EPR-type situation
A. Neumaier said:Let me remind everyone that this is a thread about Bohmian mechanics and related foundational or philosophical issues, and not about EPR or Bell. If you want to continue the discussion of the latter, please do it in a new thread linking to here, and not in this thread!
And you can have another time slicing that says exactly the opposite, so what? That is just different ways to order spacelike separated operators, in QFT they commute, so the different time-slicings are useless. I know this probably won't change your conclusion but I think there isn't much more can I do than offer you the math of QFT.stevendaryl said:I don't see how this changes my conclusion, which is that in a time slicing in which Alice's measurement takes place before Bob's, Bob's result is determined by the state at the slice on which Alice makes her measurement.
You don't think BM and Bell-EPR are closely related? Apparently Bell was basically motivated to construct his theorem by Bohm's theory.A. Neumaier said:Let me remind everyone that this is a thread about Bohmian mechanics and related foundational or philosophical issues, and not about EPR or Bell.
RockyMarciano said:And you can have another time slicing that says exactly the opposite, so what?
Right, that is realism, non-realism what I wrote above, they are incompatible. So?stevendaryl said:So, for any choice of time slicing, the future results of measurements are determined by past results of distant measurements.
