A sled is being pulled accross horizontal, snow covered ground
  • Thread starter Thread starter smaan
    Ground Horizontal
The discussion focuses on calculating the coefficient of kinetic friction for a 16-kg sled being pulled across snow-covered ground with a force of 24 N. The sled accelerates to a speed of 2.0 m/s over a distance of 8.0 m, resulting in an acceleration of 0.25 m/s². Participants emphasize the importance of using Newton's Second Law to determine the net force acting on the sled, which includes both the applied force and the friction force. The correct method to find the coefficient of kinetic friction (μk) involves calculating the friction force from the net force and the normal force, which is 156.96 N.
  • Newton's Second Law of Motion
  • Basic kinematics equations
  • Understanding of forces acting on objects
  • Knowledge of friction coefficients
  • Calculate net force using F_net = F_applied - F_friction
  • Learn how to derive the coefficient of kinetic friction (μk) from experimental data
  • Explore the implications of friction in real-world applications
  • Study the effects of different surfaces on friction coefficients
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of friction and forces in motion.
smaan
A 16-kg sled is being pulled along the horizontal snow-covered
ground by a horizontal force of 24 N. Starting from rest, the sled attains
a speed of 2.0 m/s in 8.0 m. Find the coefficient of kinetic friction
between the runners of the sled and the snow.
I have found the acceleration of the sled by using the v^2 = v0+2ax. So, 2^2 = 2(a)(8), which gives me 0.25 m/s^2. I also calculated the normal force. Since it is a horizontal plane, it would be (9.81)(16) = 156.96 N.
Not to sure how to get the μFk from here.
Thank you for your time
How might you find the friction force acting on the sled? (Hint: Newton's 2nd law.)
If that is indeed the acceleration [I don't doubt you - I have just not checked your answer] you should know the net force, and thus how large the friction that opposes the applied 24N force.
Once you have the size of the friction force, you should be able to calculate the coefficient of friction, since you have the normal force.
Would the frictional force be F=ma? So would F=(16kg)(0.25m/s^2)=4N?
So then, μk=Fk/FN. So, since I found the normal force to be 156.96 N, the kinetic friction coefficient would be 4/156.96 = 0.022548?
Newtons second law, using the actual acceleration, gives you the net Force acting.
The applied Force plus the Friction Force [adding as vectors of course] give the net Force.
The answer you give here is not correct.
No. When you use F = ma, remember that F is the net force. So it's better to write it as: ƩF = ma.
There are two horizontal forces acting: The pulling force and the friction force. Set up an equation and solve for the friction force.
Once you solve for the correct friction force, then this method will give you μk.
  • · Replies 36 ·
