A thought Experiment in Time Dilation
31 replies · 3K views
just dave
TL;DR
Something I thought of years ago that no one has answered.
Ok so here's my idea,it came to me while watching a record album spin on my turntable(I believe it was Dark Side of the Moon). Technically this exp. could be done now but the results would take a while.
You take a disc of some super strong material attach it to a ultra high RPM motor and put it in a vacuum chamber.Then spin it up to billions of rpm.Now a point near the center of this disc will not be moving very much but on the edge it's moving a lot.
Depending on the size (say it's 10 ft. in circumference) and it's speed (say 1 billion rpm) the edge of the disc is moving at 17% of c. So time slows down more on the edge of the disc then the center.Does the edge of the disc begin to disappear due to Time Dilation? How far back in time would it have to go before you noticed any effects?
Now I know there's no material strong enough to withstand the centrifugal forces or a motor that can rev up that high,that is why I called it a thought exp.This exp. could be done now but at a much slower speed and would have to run for years.
So what do you think?
just dave said:
Summary:: Something I thought of years ago that no one has answered.
What are you expecting to happen?
All others things being equal, the edge of the disc would age slower than the centre. E.g. if you had a radioactive isotope on the edge and at the centre, the isotope on the edge would decay more slowly.
No. clocks on the edge go slow but they don’t disappear. This experiment has been done using Mossbauer rotors, not as fast as you mention, but fast enough to observe relativistic effects on the edge.
I want to know would you see the edge start to disappear as it slips back in time,in effect,seeing Time Dilation right before your eyes. I think that would be pretty cool no?
Clocks on the rim of the disc would tick slowly, that's all (about 1 second per 1.01s as measured by stationary clocks in your example). There's no "going back in time" here.
It's worth noting that describing a rotating disc in special relativity can get quite complicated. In fact, developing understanding of it was one of the threads that led to general relativity.
Do you have a website or link to this experiment?
Not exactly going back but slowing down compared to the rest of the disc.
The reference is
Kuendig, Phys. Rev. 129 no. 6 (1963), pg 2371.
But I don’t have a link
Why would it disappear? It would simply in physical terms age less than the centre.
Clocks on the rim will tick slowly, that's all.
It's more complex because gravity is involved, but GPS satellite clocks have a tiny correction due to relativistic effects, including this same effect. They don't fade from view or anything.
Because it is slipping out of the present as we watch it.Time is continuing at a "normal" unaccelerated pace for us and the center of the disc.
That's not what time dilation is about.
Why would that make it disappear? It is still there, just at a different time according to its clock than according to ours.
If you and I meet and immediately look at our watches and they show different times that doesn’t mean that we didn’t meet, just that my watch said our meeting happened at a different time than your watch said.
Yes I know and elementary particles live longer when traveling at relativistic speeds. What are clocks actually measuring though? Time or our idea of time?
What is the difference?
Whatever they are measuring it doesn’t involve things disappearing because it goes slow.
We are not physically connected.The disc started out in the same time frame but now part of it is ageing more slowly than the rest of it.
Generally they are counting occurrences of some physical process: the orbit of the Earth round the Sun, the Moon round the Earth, the rotations of the Earth on its axis, the swings of a pendulum, the oscillations of a quartz crystal, the transitions of a caesium atom.
It's still physically there though!
That isn’t relevant.
Look, time dilation just doesn’t work this way. This has been done. There is no disappearing involved. Just discard that idea. I don’t know where you got it, but the world doesn’t work like that.
Yes I get it but there would have to be some other effects on the rest of the disc then.
Certainly. It will experience stress and eventually disintegrate - for the same reason the string breaks in Bell's Spaceship Paradox.
Assuming the material is strong enough to withstand the stresses from the high RPM. Would it fracture due to time dilation? Also I'm not familiar with Bell's Spaceship Paradox I'll have to look that up.
From the length contraction.
The material along the circumference will shrink - pull away from itself.
Ah. Right. The circular configuration of Bells' Spaceship Paradox is called the Ehrenfest Paradox.
That's the one you want to look up.
And it looks like - in a realistic scenario - the disc might not actually shatter. (though the stresses due to length contraction are still present.)
No. Time dilation isn't a force and it doesn't cause any mechanical stress.
I guess I'm thinking more of going back in time, more like a time machine.
In this context, all that happens is that clocks tick slowly, and length contraction means that the stresses on the disc are higher than a non-relativistic calculation would predict.
Seriously, all that happens is that the clocks on the disc tick slowly. It doesn't stop existing now or anything like that - you just have a thing that's younger than you would expect if you didn't know about time dilation.
That isn't what time dilation is. No matter how many times you ask, that answer will not change.
Even if time on the edge of the disc nearly stops? I would think that would have some physical consequence on the rest of the disc.
No.
It doesn't. Again, no matter how many times you ask, the answer will not change.
