About general solutions to Schrodinger equation
The discussion revolves around the nature of general solutions to the Schrödinger equation, specifically whether every solution can be expressed as a linear combination of separable solutions. Participants explore the implications of time-independent and time-dependent Schrödinger equations and the completeness of eigenfunctions.
  • One participant questions the assertion that every general solution to the Schrödinger equation can be built from separable solutions, noting that while separable solutions form an eigenbasis for the time-independent Schrödinger equation, this does not necessarily apply to the time-dependent case.
  • Another participant asserts that the equation in question applies only to the time-independent Schrödinger equation, suggesting that the context of the source material may have been misunderstood.
  • A participant mentions that it is typically assumed that the eigenfunctions of a Hamiltonian form a complete set, allowing any initial wavefunction to be expressed as a linear combination of these functions, with time evolution handled by the corresponding time components.
  • Some participants highlight the complexities of time evolution in quantum mechanics, particularly with time-dependent Hamiltonians that do not commute at different times, necessitating different approaches such as the Dyson series.
  • There is a discussion about the terminology used in the context of the time-dependent and time-independent Schrödinger equations, with references to specific sources like Griffiths.
  • One participant acknowledges the oversight in not specifying that the Hamiltonian in question is time-independent, as pointed out by others.
Participants express differing views on the applicability of separable solutions to the time-dependent Schrödinger equation. There is no consensus on whether all solutions can be constructed from separable solutions, and the discussion remains unresolved regarding the implications of time-dependent versus time-independent cases.
Limitations include potential misunderstandings of the context in which certain equations apply, as well as the complexities introduced by time-dependent Hamiltonians and their spectral properties.
betelgeuse91
Hi,
I am wondering why every general solution to Schrödinger equation can be built from separable solutions. In other words, I don't follow that why every solution to Schrödinger equation can be written as
$$\Psi(x,t) = \sum c_n\Psi_n(x,t)=\sum c_n\psi_n(x)\phi_n(t)$$
I know that the right hand side is a solution to Schrödinger equation but this does not mean that every solution should be of this type. I also know that separable solutions form eigenbasis of time-independent Schrödinger equation but the above fact still does not follow, as they only span the solution space of the time-independent Schrödinger equation, not the general time-dependent Schrödinger equation.
What am I missing here? Thank you for your help.
To the best of my knowledge, the above equation only applies for time-independent SE. From where did you read that it also applies for the time-dependent one? Did you not miss that the context the source is made on is implicitly the time-independent case?
betelgeuse91 said:
Hi,
It's usually taken as an assumption that the eigenfunctions of the given Hamiltonian, (##\psi_n##) form a complete set (*), in the sense that any function can be expressed as a linear combination of them. So, whatever the wavefunction is initially it can be expressed as a linear combination of these functions.
Each of these components evolves over time with the appropriate time-component (##\phi_n(t)##), so the function evolves as the linear combination you have given.
That process covers all the possibilities.
You could, however, potentially solve the Schrödinger equation another way and get a different looking solution. But, whetever solution you got would be equivalent to one of the general form given.
(*) PS somewhere in the theory of PDE's there will be a proof of this.
Well, the time evolution is a tricky problem, because it assumes a parametrization of a family of self-adjoint operators, thus a parametrization of the solutions of spectral equations. Normally, time-dependent Hamiltonians don't commute at different times, thus, for each value of "t", you need to solve the spectral equation of the Hamiltonian evaluated at "t". That's why one adopts the approximate method called Dyson series to evaluate how a solution of the spectral equation of ##H(t_0)## evolves into a solution of the spectral equation of ##H(t_1)##.
The Ansatz ##\Psi (x,t) = \sum \int c_{n,\alpha} \psi_{n,\alpha} (x,t) = \sum \int c_{n,\alpha} \psi_{n,\alpha} (x)\phi (t) ## holds only when the Hamiltonian is time independent.
dextercioby said:
Well, the time evolution is a different problem, because it assumes a parametrization of a family of self-adjoint operators. Normally, time-dependent Hamiltonians don't commute at different times, thus, for each value of "t", you need to solve the spectral equation of the Hamiltonian evaluated at "t". That's why one adopts the approximate method called Dyson series to evaluate how a solution of the spectral equation of ##H(t_0)## evolves into a solution of the spectral equation of ##H(t_1)##.
So, as soon as the "t" is fixed to a certain value, then any
Perhaps the OP can correct me if I'm wrong, but I think he is using the time-dependent Schrödinger equation to mean:
##i\hbar \frac{\partial \Psi}{\partial t} = H \Psi(x, t)##
And, the time-independent equation to be:
##H \psi(x) = E \psi(x)##
He is not talking about a time-dependent Hamiltonian. The above is the terminology in Griffiths, for example.
I found this on Griffiths page 25, "Moreover (as is typically the case with separation of variables) we will be able at the end to patch together the separable solutions in such a way as to construct the most general solution."
See post #3.
I see that the eigenfunctions of the Hamiltonian indeed form a complete set such that any function that satisfies time-independent Schrödinger equation ##H\psi=E\psi## can be written as linear combination of them. I also see that the time evolution of that function corresponds to the time evolution of each of its component. But this is a story of time-independent Schrödinger equation only. How does this make connections to general solutions of time-dependent Schrödinger equation ##H\Psi=i\hbar\frac{\partial\Psi}{\partial t}##?
I apologize that I forgot to mention that the Hamiltonian concerned here is time-independent, as PeroK pointed out.
The product ##\Psi_n(x, t) = \psi_n(x)\phi_n(t)## is a solution to the time-dependent equation.
To show you more how this works, let's assume first that the initial state is an eigenfunction:
##\Psi(x, 0) = \psi_n(x)##
Now, that initial solution must evolve according to:
##\Psi(x, t) = \psi_n(x)\phi_n(t)##
Likewise, if the initial state is a sum of two eigenfunctions:
##\Psi(x, 0) = \psi_n(x) + \psi_m(x)##
Then, that function (if it obeys the Schrödinger equation) must evolve according to:
##\Psi(x, t) = \psi_n(x)\phi_n(t) + \psi_m(x)\phi_m(t)##
And, similarly for any sum (including an infinite sum).
So, any solution must be of the general form:
1) take the initial state at time 0, and express this as a linear combination of the eigenfunctions.
2) Apply the appropriate time evolution to each eigenfunction, to give the time-dependent solution.
This relies, of course, on the theory of PDE's about uniqueness of solutions.
It looks like that what you showed here is that the time evolution of linear combination of separable solutions is ##\Psi(x,t) = \sum c_n\psi_n(x)\phi_n(t)##. But this only states about evolution of separable solutions, not evolution of general solutions. Can you state the PDE theorem here please? Maybe that's what I am missing.
It's nothing to do with separable solutions, it's to do with uniqueness. Take, for example, the quadratic equation and you get two solutions using the quadratic formula. Now, you're effectively saying: that's solutions from the quadratic formula, but what about other solutions? But, there can be no other solutions, because a quadratic equation has only two. It doesn't matter how you obtain them, once you've got them, they are the only ones.
It's the same with PDE's. If there is a unique solution, then it doesn't matter how you find it (in this case building it up from separable components). Once you've found it, it must be the only solution.
Note, also that the general solution:
Is not itself a separable function. It is a sum of separable components, but cannot itself be written in the form ##\Psi(x,t) = f(x)g(t)##
In other words, it is the most general solution and is not separable.
! I see. So the set of solutions we found as above is indeed the set of all the possible solutions by uniqueness. Thank you very much, now I understand what was going on!
Well, the story is not so simple. First of all, the Schroedinger equation, when the Hamiltonian is known and expressed in terms of other dynamical observables (let's choose momenta and coordinates, as is the case for the homogenous D-dim. harmonic oscillator or 3-D Hydrogen atom) is a linear partial differential equation of second degree. For example:
\frac{\partial\Psi (t,x,y,z)}{\partial t} = \frac{1}{i\hbar} \left(-\frac{\hbar^2}{2m}\Delta \Psi(t,x,y,z) + K (x^2 + y^2 + z^2) \Psi(t,x,y,z) \right)
But in mathematics, a PDE (linear or not) is well-formulated only in the presence of initial conditions or boundary conditions. These initial conditions apply to physical equations in which time is a variable, so one needs to have given (i.e. known) ##\Psi (t_0,x,y,z) = f(x,y,z)## on one hand, then Cauchy (i.e. both Dirichlet and Neumann) boundary conditions such as ##\Psi (t,\infty,y,z) = 0 ## and ## \left[ \partial_{x} \Psi (t,x,y,z)\right]_{x=\infty} = 0 ##. ONLY UNDER THESE conditions, as per the Cauchy-Kovalevskaya theorem, the PDE has a unique solution.
This means that no matter what resolution technique I use (separation of variables, change of variables, method of characteristics, reduction to an ODE through Laplace or Fourier transformation), once I found the solution which solves the equation & the boundary conditions I have, then this is it. Physicists are very fond of separation of variables, but, according to the symmetries (and here Sophus Lie was the pioneer) or other criteria, it's not the only way to solve a PDE.
  • · Replies 39 ·
  • · Replies 17 ·
  • · Replies 24 ·
  • · Replies 19 ·
