Absolute Time Clock Experiments: Einstein's Special Relativity
  • Context: Graduate
  • Thread starter Thread starter roineust
    Absolute Clock Time
204 replies · 34K views
Hey DaleSpam,
Exactly! I am being referred again and again (not just by you) to this huge list of past experiments, and it just blurs the issue. I am looking for just one or for a few specific experiments, that can be compared to diagram 2. Otherwise it is very hard to understand what exactly it is that bothers me and to either affirm or negate this possibility in a structured way.Roi.
roineust said:
Please refer me to an experiment that was already executed in the past and that attempted what is shown in diagram 2. What I mean is an experiment that tells us that the laws of physics are the same in any inertial frame, regardless of position or velocity. Many experiments that I heard of do not apply, either because: 1. The complete experimental action is not done from within the inertial frame itself with results recorded and sealed way before velocities are equaled. These experiments are a result of having the experiment not complete before and part of the action of both frames meet at the same velocity. Or: 2. These experiments are not attempted at relativistic speeds.
Roi, is the essence of your experiment that light must start from one source, be split into two paths where one of the paths has a medium that slows light down while the other one doesn't and then you want to see if the relative arrivals of the light from the two paths when they come together is influenced in any way by the experiment being performed under different states of motion?
And is it your contention that such an experiment would show a difference and from that difference an absolute ether rest frame could be determined?
Hello ghwellsjr,
Yes,
But it is not a contention.
It results from not being able to understand time dilation.
Thanks,
Roi.
Have you read the page? The issue is not the absence of one strange experimental apparatus that you dreamed up, the issue is that the existing evidence is overwhelming.
...in other words, any new theory would still have to be mathmatically equivalent to Relativity as applied to those other experiments.
Roineust, I don't think that you actually need some specific experiment to be performed. What you need is to better understand the theory. All classical (non quantum) EM phenomena are governed by Maxwell's equations which are invariant under the Lorentz transform. It doesn't matter if you are talking about some EM in a crystal or in a jumble of wire. They will both be dilated by the same amount.
Hello Russ,
Absolutely! but maybe up to this point not all possible behaviors of ether have been considered? for example, why can't this type of ether be non-luminiferous as well as non-matter friction at once? Can you help me understand the meaning of static vs. non-static ether? I am trying to understand all the qualities and properties that were historically ever attributed to ether. This way I will try to sort all ether types that were suggested.
Thanks,
Roi.
DaleSpam,
Is your suggestion actually to go over and over again through the mathematics of Maxwell and Lorentz equations, and when I will be sure that I understood each and every derivation and other mathematical operations in each and every line, then and only then, will I suddenly understand time dilation? I am having a hard time believing that this is what designates a person who understands time dilation form the one who does not.
Roi.
That is not my suggestion, but I do think it is a good suggestion. I would highly recommend that you do so. You should probably spend more time working homework-type problems though, rather than going through derivations.
DaleSapm,
I went through these equations a couple of times in the past, and it was hard, long and suspenseful enough to do this while thinking that I will understand at the end that 'magic notion' of time dilation. The disappointment of finally not understanding time dilation at the end of that rigour learning process, was big enough not to want to go over these specific equations again.
Roi.
Did you work any homework-type problems?
The other thing that helped me learn a lot was doing spacetime diagrams and learning about four-vectors.
Some, not much - it came back to using real numbers with the gama factor, and calling it space ships flying this way or another. It worked out mathematically but it did not change my ability to understand it.
For example, when I was first taught, years ago, that you can use a complex set of pulleys to manually lift up a very big mass, it seemed to me no less a magic than time dilation later seemed, but when I learned the math and made some exercise, my 'head' and 'guts' totally 'hooked up' together again, and it didn't seem to feel like a magic any more, just a very 'cool' thing to understand. So the same with many other even more complex pre-modern physical phenomenon. But this one phenomenon of time dilation could never 'settle down' in my head.
And of course, that is why I also never even attempted to go further and try to understand quantum mechanics phenomenon or GR phenomenon. Besides I was told that SR math is relatively simple compared to these later developments, so why bother understanding stuff like quantum particles jumping between parallel universe, if the math describing such 'more than magic' phenomenon is so complex, while much simpler math, that describes just a much simpler 'magic', I can not even have any real feeling of understanding about.
Roi.
Roi, have you studied the historical interpretation of MMX (prior to Einstein) and how Lorentz (and others) concluded that the experimental apparatus was length-contracted in the direction of motion and experienced time dilation? This conclusion was based on an absolute ether rest frame, so I think it is easier to grasp. From there, it is an easy step to SR.
Hey ghwellsjr,
Yes I have tried to understand SR this way as well.
What I don't understand regarding the phenomenon of length contraction, and grasping by it the idea of ether as the cause of this phenomenon, by the way of it becoming a preparatory concept, that when assimilated correctly by the student, brings him to a point where SR is understood, while at the very same time, somewhat mysteriously, he also understands why actually the ether itself, as an entity of having any real physical properties, is redundant, is this:
1. First of all when completing this lesson the student will feel a little bit 'cheated', because he will ask himself if bringing up length contraction and ether, was just in order to never bring up these entities again, without any explanation. And then it gets worse:
2. I saw this problem brought up by many SR students: How can you build an experiment showing length contraction? When the answer here is, that there is no such experiment, then, in the way of accepting the conclusion of time dilation that happens by no means of ether, at least in my mind as a student of SR, the way to get to that conclusion becomes barricaded again, even if the teacher will say, 'hold on a minute!' and go on to time dilation.
That is because the student will feel that he never got an answer to a concrete part of the course of events described by the teacher - e.g. an experimental proof of length contraction! not some mathematical complexity, that he can work out later by himself!
3. If a SR student such as me, gets 'stuck' with understanding SR at the point described above, and will understand that bringing a proof of length contraction is impossible, he may start thinking that it is all a result of science not having yet enough experiments that were built with advanced enough equipment to prove a type of ether, that actually has nothing to do with length contraction.
At this point the student will feel that he must invest much more in understanding the history of ether experiments than in the history resulting from SR conclusions. Here are some thoughts I came up with at this stage:
- An atomic clock does not work the same as the device in diagram 2 that I made. An atomic clock has only the 'upper' part of that device, e.g. only one electromagnetic signal going towards a counter, but it has no comparison between two electromagnetic signals within one device.
So if an ether of the type I am looking for exists, it will cause time dilation, but it will not cause the effect of dis-synchronization between the two signals. And such an effect will be considered a change of physical laws as a result of velocity differences - but it can not be found at present experimental structuring.
- The jets carrying these atomic clocks, where moving at a non-relativistic velocity, so maybe also jet speed is not enough to prove the existence of time dilation as a result of ether, maybe some sort of a very small device put in a powerful accelerator should be built.
-Any other experiment that proves time dilation by properties of accelerated particles, again works in the same way as the atomic clock - with no comparison of two synchronized signals compared before and while relative movement.
- At this point, I am usually told that C invariance is not inconsistent with time dilation, because it is somehow mathematically separate from light, although light moves inside that same time dilated frame - but I was never given, in my point of view, any good explanation to think there is no contradiction here.
And therefor my reasoning goes on and maybe this type of ether can resolve that contradiction by somehow having light not affected by ether, while matter is affected in a some non-friction way.
- Then the most dissident thought of such a student as myself will conclude - never mind the exact properties of such a type of ether, what is sure is that if you have a device that can tell you, without recording acceleration and without 'looking out of the window' of the 'jet', that you are at a different speed, then there must be some kind of ether - and this is something that not only Einstein rejected, but also Newton and Galilei - so maybe it is just a matter of advance enough experimental technology, in order to put all these three huge figures together, as correct but not enough precise, in their theories ability to describe and explain, what might be experimentally discovered in the future.
This is really, really starting to sound crackpotty.
Roineust, from the point of view of someone only looking at this thread casually, it appears that people here are telling you things you should learn, and you're coming in with reasons why you shouldn't follow the path they are pointing you to. I think you should back off on your statements, and follow their advice.
And yes, I am afraid that means mathematics.
You may want to try a more geometrical approach with spacetime diagrams and four-vectors. In the end that is what "made it click" for me.
roineust said:
For example, when I was first taught, years ago, that you can use a complex set of pulleys to manually lift up a very big mass, it seemed to me not less a magic than time dilation later seemed, but when I learned the math and made some exercise, my 'head' and 'guts' totally 'hooked up' together again, and it didn't seem to feel like a magic any more, just a very 'cool' thing to understand. So the same with many other even more complex pre-modern physical phenomenon.
That is why I wouldn't give up on this approach yet. You don't seem like you have worked enough problems to be proficient yet.
Vanadium,
Please leave me at quiet with such words as crackpotty.
Thanks,
Roi.
This is factually incorrect. They detected relativistic effects therefore, by definition, they were moving at relativistic speeds.
Hey DaleSpam,
Might be - maybe it depends on the technological ability to record minor dis-synchronization between the pulses coming from the two light sources in diagram2.
roineust said:
Vanadium,Please leave me at quiet with such words as crackpotty.
Then adopt a different viewpoint.
There is a common theme in messages by crackpots. "I haven't really studied the theory, at least not quantitatively , but I am sure that it's wrong and the people who have studied it are wrong too". The closer you get to that theme, the fewer people will listen to you. I am trying to make the point that you are getting very close to that.
The title of this thread is the SR equivalent of the Newtonian "A Perpetual Motion Machine!" If someone were to post that, and then refuse to gain the mathematical background to understand (algebra, in both cases) what would the reaction be?
roineust said:
Hey ghwellsjr,
Roi, I wasn't asking you to understand SR historically, I was asking if you studied how length contraction (and time dilation) was used by Lorentz (and others) to explain the null result of MMX prior to SR. At this stage, it is important to NOT try to understand SR. Forget about what happened after Einstein's 1905 paper came out.
I just want you to answer that one question: do you understand how length contraction explains why MMX could not detect an ether wind?
Hey ghwellsjr,
I have sat in a classroom thorough all of SR course.
I did it only twice (once in a real room and once watching on a video course portal), and made just a little amount of homework in the subject. I am not sure if this answers your question. I remember equations with a big L and a little l, the v and v' and other variables and part of equations. I didn't go through this extraordinary frustrating process lately again (most of all frustrating because this process did not explain time dilation to me).
Thanks,
Roi.
Vanadium 50,
I'v dealt with such expressions all my life. I am not lazy. so please stop.
How does this thread represent a contradiction with the laws of energy conservation?
Thanks,
Roi.
roineust said:
Hey ghwellsjr,
Thanks,
Roi.
And do you understand what it means for a set of equations to be "Lorentz invariant"? Do you understand for example that if we know the correct equations to describe the laws of physics in one frame, the question of whether or not these laws are Lorentz-invariant is a purely mathematical issue, not an experimental one? (though of course it is an experimental problem to determine whether we have the equations precisely correct in that one frame). Likewise, do you understand that if the laws are Lorentz invariant this guarantees they will work the same in all the different inertial frames of relativity, and that any physical systems governed by these laws (including clocks) is guaranteed to obey time dilation as SR predicts? In this sense Lorentz-invariance "explains" time dilation, although of course physics cannot "explain" why the universe obeys one set of mathematical equations as opposed to some others, this is a question for philosophy or theology.
Hey DaleSpam,
What you say in post 46 I absolutely agree with.
On the other hand I gave it my best, and couldn't understand it (SR), although I understood each and every mathematical move. Telling me to go into an endless loop of starting again every time I get to the end and still time dilation looks like magic, doesn't make sense to me.
Anyway, I will try to check out if a geometrical approach makes it seem a different path, in understanding time dilation.
Thanks a lot,
Roi.
JesseM,
You might be right. I don't know.
Roi.
It is a difficult subject. It took me 7 years of sporadic study before I understood it.
I highly recommend it. There are two things which made it finally "click" for me:
1) Spacetime diagrams
2) Four-vectors
For 1) in particular I did a diagram where I used the Lorentz transform to draw the t'=0, t'=1, t'=2, x'=0, x'=1, and x'=2 for a primed frame moving at v=0.6. When you do that you can look at your diagram and visually see the invariance of c, relativity of simultaneity, length contraction, and time dilation and how they all fit together.
Merry Christmas everyone!
Can someone explain to me why diagram 2 depicts a contradiction with the laws of energy conservation (a 'perpetum mobilum’)? Is this exactly the same issue as with time dilation, or maybe it is simpler to explain? Because, for example, I know that in old ‘perpetum moblium’ machines, what happens is that they stop working because of friction, but what diagram 2 has to do with friction or with a ‘perpetum mobilum’ at all?
Thanks,
Roi.
roineust said:
Hey ghwellsjr,
Thanks,
Roi.
Roi, chances are those classes did not teach how Lorentz explained the null result of MMX using Length Contraction and Time Dilation. It can be done purely graphically with very little math. Would you like me to walk you through this exercise?
