AC Frequency UK: Why Does Filament Lamp Flash 25Hz?
  • Context: Undergrad
  • Thread starter Thread starter James2020
    Ac Frequency Uk
The filament lamp connected to the UK mains flashes at 25 times per second, which is half of the 50 Hz AC frequency. This phenomenon occurs due to the interaction between the camera's frame rate of 120 fps and the expected 100 Hz energy emission from the lamp. The observed flickering is a result of aliasing, as per Nyquist's Sampling theorem, which states that to accurately capture a 100 Hz signal, a sampling rate of at least 200 Hz is required. To eliminate flicker issues, using DC lighting is recommended.
  • Understanding of AC frequency, specifically 50 Hz in the UK
  • Familiarity with Nyquist's Sampling theorem
  • Knowledge of aliasing effects in video and audio
  • Experience with high-speed camera operation and frame rates
  • Research DC lighting solutions for flicker-free illumination
  • Learn about high-speed camera specifications and their impact on video quality
  • Explore techniques to mitigate aliasing in both video and audio recordings
  • Investigate the effects of different frame rates on capturing AC-powered light sources
Filmmakers, electrical engineers, photographers, and anyone interested in understanding the effects of AC frequency on lighting and video recording.
James2020
When I record slow motion video of my filament bulb lamp connected to mains, I can be completely sure that it flashes 25 times per second. This is half of the 50 hertz AC frequency. I would expect it to flash 100 times per second as the current reaches a node twice per cycle in it’s AC wave. Why is this not the case.
Welcome to PF.
Does the filament lamp have a dimmer?
What is the frame rate of your camera?
No the lamp doesn’t have a dimmer.
The frame rate of the camera is 120fps whilst recording in slow motion. I can observe the lamp visibility dimming & brightening so it certainly seems that the frame rate is high enough.
Thank you.
You are probably observing the beat between the 120 FPS and the 100 Hz energy emission you expected. Based on those numbers, the difference frequency is 20 Hz.
The camera is recording 'samples' (frames) of the scene. Nyquist's Sampling theorem says that, to get an accurate version of a changing scene, you need to sample at twice the rate that the scene is changing. If you are looking to record 100Hz variations correctly then you would need (significantly more than) 200Hz sampling rate. What you are seeing is referred to as an Alias. @Baluncore correctly describes it as a "beat". It's just like the wagon wheels going backwards on old films.
To avoid this problem, use DC lighting!
It's easier to describe the same effect in audio. Digital sound ADCs always use a low pass filter at half the sampling frequency to prevent aliases of high input frequencies turning up as low frequency aliases. Your digital camera has a spatial filter (fuzzy layer over the sensor) to avoid jazzy alias patterns. And we all (?) remember the problem of fine patterns on clothing producing distracting aliases when displayed on analogue colour TV. (Yes- sampling problems come in on analogue systems too)
My guess is that the camera was designed to operate at 120 fps so as to have a zero flicker rate when operated in countries like the USA that have 60 Hz power.
It is possible that it can be switched to 100 fps for use in countries where 50 Hz power is used.
I am having the same problem with my CMOS astro camera when I try to use it indoors. The sharp on/off of LEDs in the home makes it hopeless for decent indoor shooting. The flicker is terrible and I can't use more than about 30fps. I must buy some oil lamps.
High speed cameras present a lot of problems with data capture. USB3 is needed and that (another story) is not without its problems.
@James2020 what is your method of recording at the fast frame rate?
Aha, a renaissance man.
Oil lamp lighting is very pleasant, and IMO good for mental health. Not good for reading books, but fine for reading backlit screens.
  • · Replies 78 ·
17K
26K
  • · Replies 31 ·
