Accelerating wedge with friction
The discussion focuses on determining the minimum horizontal acceleration required for a block to remain on an inclined wedge without sliding, given the coefficient of friction and the angle of inclination. Participants explore the forces acting on the block, including gravitational, normal, and frictional forces, and the impact of the wedge's acceleration. The correct formula for the minimum acceleration is identified as a_min = g(1 - μ)/(1 + μ), with emphasis on considering inertial forces in a non-inertial frame. The conversation highlights the importance of accurately accounting for all forces to derive the correct solution. The exchange concludes with participants clarifying their understanding of the problem dynamics.
Patta1667
A block rests on a wedge inclined at angle \theta. The coefficient of friction is \mu. The wedge is then given a horizontal acceleration a. Assuming that \tan (\theta) < \mu, find the minimum acceleration for the block to remain on the wedge without sliding.
I've been working angles like crazy and can't even get the theory down, much less come up with the equation. The block would slide off the wedge if not given an acceleration, and once the min. acceleration to keep the block on the wedge is reached the force of friction changes direction and will now be pointed down the wedge if acceleration increases.
I don't want a worked solution, only some help explaining the forces at work in this problem.
Draw all the forces acting up the plane and down the plane. Then draw in the acceleration a.
For the wedge to not movie, what should the resultant acceleration be?
If the block is not sliding, then it must be that the friction force is giving the block the same acceleration as the wedge. What is the maximum horizontal component of the friction force, and the corresponding maximum acceleration that friction can give the block?
Okay, the maximum friction force along the surface is \mu N, so the horizontal component is f \cos \theta = \mu N \cos \theta = \mu m g \cos^2 \theta. This means the block has an acceleration a = \mu g \cos^2 \theta horizontally if friction alone is responsible.
Unfortunately, using \theta = \pi/2 yields a = \mu g/2. The correct answer is a_{min} = g \frac{1 - \mu}{1 + \mu}. Any ideas?
Sorry I misread the question. Give me a minute to post a correct response.
I keep getting the answer
a_{min} = \frac{g(\sin \theta - \mu \cos \theta)}{\cos \theta + \mu \sin \theta}
Ooops, let \theta = \pi/4 to get that answer... sorry! Well, could you lead me in the right direction please on how you obtained that?
Ok, it's a little messy working in the original frame, so switch to a frame moving with the wedge. Since the wedge is accelerating, this frame is not inertial, so you will have to add a horizontal force ma to the block. So you have the weight, friction force, normal force and inertial force. The normal force is found in the usual way using the condition that the block is not accelerating perpendicular the incline. Then you find the friction force from the normal force. You find amin by equating the component of the total force parallel to the incline to zero, i.e. imposing the condition that the block is not sliding.
Thank you! I had taken N = mgcos(theta) in all my equations, I completely forgot that the inertial force should be considered. The answer comes right out now, thanks!
No problem. :smile:
  • · Replies 37 ·
  • · Replies 43 ·
