Acceleration due to gravity problem.Help
The discussion centers on calculating the acceleration due to gravity on Mercury, given its mass of 3.30 x 10^23 kg and a diameter of 4878 km. The user correctly converts the diameter to radius in meters and applies the formula Gmp/rp², using the gravitational constant G = 6.67 x 10^-11. The calculated acceleration due to gravity is approximately 3.70 g, which is confirmed by another participant who appreciates the clarity of the solution. Additionally, a rough check suggests that the expected gravity should be about 40% of Earth's gravity, aligning with the calculated value. The problem is ultimately deemed solved.
NewtonJR.215
"Determine the acceleration due to gravity on the planet Mercury which has a mass of 3.30*10^23kg and a diameter of 4878 km.
Gmp/rp2
Mp is mass of planet
Rp is radius of planet
First off I needed to change the diameter into the radius. In my class I have to convert km to m.
4878 km*1000= 4,878,000 m
4,878,000/2= 2,439,000
2,439,000 is the radius
Next, plugged in.
G=6.67*10^-11
Gmp/rp2
(6.67*10^-11)(3.30*10^23)/2,439,000^2 = 3.70 g on Mercury.
I'm pretty sure this is correct just want to make sure. Thanks for looking it over!
Welcome to PF!
NewtonJR.215 said:
Gmp/rp2
Hi NewtonJR! Welcome to PF! :smile:
That's a very well-laid out solution … I can see exactly what you're doing!
Yes, that's fine … except I think you don't mean that "g" at the end, do you? :smile:
btw, as a check (which is often useful to make sure we're not 1000 out!), if we assume that Mercury's density is roughly the same as the Earth's, then mass is proportional to r³, so surface gravity is proportional to r, so should be about 40% of g, = about 4. Yippee! :biggrin:
Thanks for the welcome! Thanks for the feedback also. No, I didn't mean to put that "g" at the end.:cool:
This problem is SOLVED.
  • · Replies 62 ·
