Acceleration Equations for Unknown Masses
14 replies · 3K views
dance_sg
13. Which expression represents an equality between accelerations?
A) Gme/r = v/r
b) Gme/r2= v/r
C) Gme/r2= v2/r
D) √Gme/r= v/r2
i have no idea how to figure this out.
If you can't automatically see it. Write out the units of each one and see if you get m/s2 on the left and right sides.
Also, seeing the terms on the left side, do know a formula for acceleration? Do the same for the right side with the terms v and r.
It's a question of units. In which answer, if any, do the left- and right-hand sides both have the units of acceleration?
so i know for sure answers b and c do, but what about the other sides. a=v/t is an equation, but that's not an option..
Since answers b and c are different in the right-hand side, they can't both be correct. It is a question of units, not of any particular equation that might represent an acceleration.
but for v and r, it would be m2/s, rather than m/s2
v is m/sec, and r is m, so, for instance, v/r is
[tex]\frac{\text{m/sec}}{\text{m}} = \frac{1}{\text{sec}}.[/tex]
Is that acceleration? You have to do the same kind of "calculation" for each possible answer.
o thank you! that makes way more sense. :D
i have one more question if u think you could answer it,
-When the distance separating two masses, M and m, is 1.2 x 1010 m, the gravitational force of attraction is 5.0 N. If the mass of M becomes 3M and the separation distance becomes
2.4 x 1010 m, what will be the force?
A. 0.27 N
B. 2.2 N
C. 3.8 N
D. 7.5 N
what equation am i suppossed to use for that??
A. 0.27 N
B. 2.2 N
C. 3.8 N
D. 7.5 N
Maybe a formula that contains M,m and an r ? Perhaps a constant like G in it as well.
You're supposed to use the equation for for the gravitational force between two bodies.
You should also start a new thread for a new question, so other people can find it easily.
but taht formula doesn't have force in it.
Sure it does; it defines the force.
o sorry. i will know for next time. and ok. so Fg=GmM/r^2. but in the equation it tells us the distance between the two. not what each equals. how do i solve that?
You can write two equations: one for the initial conditions, and one for the second set of conditions. G is known; you are given the force in the first situation, and the distances; you are given the second set of masses in terms of the first; but you don't know the masses m and M. You need to somehow get rid of m and M from the equations. If you actually write down the equations, the technique should jump out at you.
