Acceleration for Position-time graphs
The discussion revolves around interpreting acceleration in position-time graphs. In the first graph, a negative slope indicates the object is speeding up, resulting in negative acceleration. Conversely, the second graph also has a negative slope but shows the object slowing down, leading to positive acceleration. The confusion arises from understanding the relationship between slope steepness and acceleration direction. Clarifying the second derivative's role in determining acceleration helps resolve the misunderstanding regarding the graphs' behaviors.
Yodaa
Yodaa said:
1. http://www.physicsclassroom.com/Class/1DKin/U1L3a16.gif
2. http://www.physicsclassroom.com/Class/1DKin/U1L3a17.GIF
In the first graph, I get that that the slope is negative and that the object is speeding up
And in the second graph, the slope is negative and the object is slowing down
But I'm unable to understand why the first graph has negative acceleration while the second one has positive acceleration?
Your question reversed the graphs?
In the first graph, the slope is getting steeper, speed up.
In the second graph, slope is getting less steep, slowing down.
Acceleration is the second derivative of the position versus time... :smile:
@berkeman I am sorry i don't understand how that relates to negative acceleration for the first and positive acceleration for the second:oldconfused:
@mathman that is exactly what i mentioned above...
Do you understand the difference between the 2nd derivative of y=x2 and y=-x2?
Plot each of those two functions, and look at the nature of the curvature. One is curving UP, while the other is curving DOWN. So which one will give you a positive second derivative, and which one will give you a negative second derivative?
Zz.
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 49 ·
