Acceleration from 2 Force Vectors
The problem involves two forces, F1 and F2, acting on a 2.00 kg object, with F1 specified as 30.0 N along the x-axis and F2 as 10.0 N at a 60-degree angle to F1. The objective is to determine the magnitude and direction of the resulting acceleration.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of acceleration components using trigonometric functions and question the correctness of their values for ax and ay. There is also a focus on the method for determining the angle of acceleration based on these components.
The discussion is ongoing, with participants providing various insights into the calculations and questioning the accuracy of the values used. Some guidance has been offered regarding the use of trigonometric functions, but there is no clear consensus on the correct approach or values.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for showing work and using units consistently. There is also a noted confusion regarding the application of trigonometric functions in the context of the problem.
zcabral
Two forces, F1 and F2, act on a 2.00 kg object where F1 = 30.0 N (on the x-axis) and F2 = 10.0 N. A 60 degree angle is between them. Find the magnitude and direction of the acceleration.
http://www.webassign.net/pse/p5-15.gif (ignore figure a)
F=ma
a=sqrt. (ax^2 + ay^2)
I figured out that the magnitude is a=sqrt. (ax^2 + ay^2)
which is equal to 17.67
however i can't get the correct direction! i thought it would be theta = arctan (2.5 /17.5)= 8.13 but it keeps saying its not the right answer! help
The angle should be arctan (a_y/a_x).
General rules for these problems:
Use units throughout.
Combine the two forces into a single one.
Show all work.
i did that and it didnt come out right
Where did you get the numbers 2.5 and 17.5? What are they?
2.5= ay
17.5= ax
together they are the acceleration = 17.67 (im 100% sure)
i got them by using this technique
Fx= 30cos(0)+10cos(60)= 35
A=F/m A= 35/2 A= 17.5
Fy= 30sin(0)+10cos(60)= 5
A=F/m A= 5/2 A= 2.5
zcabral said:
2.5= ay
17.5= ax
A=F/m A= 5/2 A= 2.5
Redo your calculation of Fy.
oops no i used sine just didnt type it out right here
But 10 \sin(60) \ne 5
why is it the cos(0) and sin(0)
Because the angle that the 30 N force makes with the x-axis is 0. (That force is along the x-axis.)
how do i find out the angle is i have the magnitudes??
9K
13K
10K
