Acceleration of a fluid particle
The discussion revolves around the acceleration of a fluid particle, specifically focusing on the mathematical representation of the velocity vector and its derivatives in the context of fluid dynamics. Participants are examining the relationship between the total derivative and the material derivative of the velocity field.
  • Conceptual clarification, Mathematical reasoning
  • Participants explore the definition and implications of the total derivative in relation to the acceleration of a fluid particle. There are attempts to clarify the transition from the notation of U to u in the context of the total derivative expressions.
The discussion is active, with participants questioning the application of the total derivative and its relevance to the problem at hand. Some have provided clarifications regarding the definitions and relationships between different derivatives, while others are seeking further understanding of specific terms and their implications.
There is an emphasis on ensuring that the definitions used are consistent with the problem setup, particularly regarding the dependence of U on both spatial and temporal variables. Participants are also navigating the nuances of notation in fluid dynamics.
coverband
1. The velocity vector which describes the motion of a particle (point) in a fluid is [tex]\vec {u} = \vec {u}(\vec{x},t),[/tex] so that the particle follows the path on which [tex]\frac {dx}{dt}=\vec{U}(t)=\vec{u}[\vec{x}(t),t].[/tex]
Write [tex]\vec{x}\equiv (x,y,z)[/tex] and [tex]\vec{u} \equiv (u,v,w)[/tex] (in rectangular Cartesian coordinates), and hence show that the acceleration of the particle is [tex]\frac {d\vec{U}}{dt} = \frac {\partial \vec{u}}{\partial t} + (\vec {u} . \nabla) \vec {u} \equiv \frac {D\vec {u}}{Dt}[/tex], the material derivative
Acceleration of particle = [tex]\frac{d^2 x}{dt^2} = \frac {dU}{dt}=\frac{du}{dt}[\frac {\partial x}{\partial t}, \frac {\partial y}{\partial t}, \frac {\partial z}{\partial t}, 1][/tex]
[tex](\vec{u}.\nabla)\vec{u} = uu_x\vec{i} + uv_x\vec{j} + uw_z\vec{k} + vu_y\vec{i} + vv_y \vec{j} + vw_y \vec {k} + wu_z \vec{i} + wv_z \vec{j} + ww_z \vec {k}[/tex]
Got it! Thanks..
Wait! The total derivative. How does that help ?
[tex]\frac {dU}{dt} = \frac {\partial U}{\partial t} + \frac {\partial U}{\partial x} \frac {dx}{dt} + \frac {\partial U}{\partial t} \frac {dt}{dt}[/tex]
This isn't the total derivative, this is:
[tex]\frac{dU}{dt}=\frac{\partial u}{\partial t}+\frac{dx}{dt}\frac{\partial u}{\partial x}+\frac{dy}{dt}\frac{\partial u}{\partial y}+\frac{dz}{dt}\frac{\partial u}{\partial z}[/tex]
Note that the last three terms look like:
[tex]\frac{dx}{dt}\frac{\partial }{\partial x}+\frac{dy}{dt}\frac{\partial }{\partial y}+\frac{dz}{dt}\frac{\partial }{\partial z}=u_x\frac{\partial}{\partial x}+u_y\frac{\partial}{\partial y}+u_z\frac{\partial}{\partial z}=\mathbf{u}\cdot\nabla[/tex]
Which is what you're looking for:
[tex]\frac{dU}{dt}=\frac{\partial u}{\partial t}+\left(\mathbf{u}\cdot\nabla\right)u[/tex]
This last formula is also called the convective derivative or the material derivative.
Very helpful thank you. Just one quick question. Why does U become u in your total derivative expressions. Thanks again.
Because you have [itex]U(t)[/itex] defined as [itex]U(t)=u\left[x(t),t\right][/itex] in the problem. If [itex]U(t)[/itex] is only a function of [itex]t[/itex], then [itex]\left(\mathbf{u}\cdot\nabla\right)u=0[/itex] and [itex]dU/dt=\partial U/\partial t[/itex], which is not what you want for this problem.
Glad I can help.
  • · Replies 32 ·
