Acceleration of a triple Atwood Machine
The discussion focuses on the dynamics of a triple Atwood machine, emphasizing that the acceleration of the blocks is not uniform due to the differing masses and the constraints of the pulley system. Specifically, it is established that while blocks 1 and 2 can move independently, block 3's acceleration is influenced by the tension in the string and the mass of the other blocks. The conversation highlights the importance of understanding the relationship between the lengths of the string sections and the resulting accelerations, which can be derived from the fundamental equation F = ma.
  • Understanding of Newton's Second Law (F = ma)
  • Familiarity with pulley systems and tension forces
  • Knowledge of kinematics and acceleration concepts
  • Ability to differentiate equations to analyze motion
  • Study the mechanics of pulley systems in detail
  • Learn how to derive relationships between accelerations in multi-block systems
  • Explore advanced kinematics involving multiple constraints
  • Investigate the effects of mass distribution on acceleration in Atwood machines
Physics students, educators, and anyone interested in understanding complex mechanical systems, particularly those involving multiple pulleys and varying masses.
Calpalned
http://photo1.ask.fm/723/921/945/-419996993-1shh761-9gamg0f647hgbk/original/IMG_4081.jpg
There is no friction at all and this is a pulley system. The pulleys and string are mass-less. The numbers correspond to the block weight (ex: 3 = 3kg).
F = ma
From my solutions guide, it seems that the acceleration of block 3 is not equal to the other two blocks. I do not understand this. They are all connected by the same string and therefore are influenced by the same force of tension.
F = ma
What forces act on the hanging block?
The length of the rope is unchanged, but it is shared among the two horizontal pieces and the two (equal) vertical pieces. They do not need to change with the same rate. Imagine that block 2 is very-very-very heavy, so it is practically stationary...
I see... so the blocks don't have the same acceleration?
If that's the case why do the two blocks below have the same acceleration? Here the blocks have different masses and are connected by the same string. The pulley system in my first post also only uses one string, but yet acceleration varies?
It's a different situation.
In post #1, if you hold one of the blocks still, the other two blocks still have freedom to move. But in that picture in post #4, if you hold one of the blocks still, the other block cannot move (without the rope becoming slack).
Can you see how if block 3 in post #1 was fixed, block 1 and 2 can still move left or right? This is why they don't have to have the same acceleration; there is more freedom in the system.
You can see block 1 and 2 have the same force of tension acting on them (right?) so they will in fact have different accelerations.
In that picture, the string consists of just two straight sections, and the sum of the lengths must be constant. You can write that down as an equation and differentiate it twice to show the relationship between the two accelerations. In the diagram at the start of this thread, there are four sections. Again, the sum of the lengths is constant, and that gives you an equation relating the accelerations, but in this case there are four variables, so there are many possible solutions to this equation. You need to look at forces to figure out all the acelerations.
9K
