Acceleration of the particle at t = 1s
The position of a particle moving along the x-axis is defined by the equation x = 15e-2t m. To determine the acceleration at t = 1 s, one must first find the velocity by differentiating the position function with respect to time. The acceleration can then be derived by differentiating the velocity function. Clarification on the original equation format is necessary for accurate assistance. Understanding how to manipulate these equations is crucial for solving the problem effectively.
patelneel1994
The position of a particle as it moves along the x-axis is given by x = 15e-2t m, where t is in s. What is the acceleration of the particle at t = 1 s?
d = vi.t + 1/2 a ts
since I don't know how distance is implemented.
I couldn't do it
= 15e-2t = 0 + 1/2 a 1 s2
Can't you find a value for x with the equation you have? That should be all you need!
d = vi.t + 1/2 a ts
I couldn't do it
Per the forum rules, you must at least try and show your effort before help is allowed.
And at the very least, please put some effort into making it easy to read what the problem actually is. Do you really mean that
x = 15e - 2t [m]?
Or do you mean,
x = 15e-2t [m]?
Or is it,
x = 0.15t [m]?
One is much more likely to get help if one does the due diligence to make the original post easy to read.
If you are given the position as a function of time, x = f(t), what operation do you need to perform to find the velocity function? And what to get the acceleration function?
To find the velocity = delta x/ delta t
What operation does \frac{\Delta x}{\Delta t} become as \Delta t and the corresponding \Delta x become smaller and smaller to the point of being infinitesimally small?
In other words, if you graph x(t) vs. t (x on the vertical axis and t on the horizontal axis), what is the slope of the curve at any point in time, t?
  • · Replies 28 ·
