Acceleration of two masses and a pulley
The discussion centers on the dynamics of a massless pulley system with two hanging masses, m and M, affected by an external force F. The equations of motion derived include T = ½F for tension, leading to the accelerations am = ½(F/m) - g and aM = ½(F/M) - g for the respective masses. The acceleration of the pulley, aP, is determined to be aP = ½am + ½aM, reflecting the influence of tension on both sides of the pulley. The analysis concludes that when the masses differ, their accelerations will vary, with the smaller mass accelerating faster than the pulley.
  • Understanding of Newton's second law (F = ma)
  • Basic knowledge of pulley systems and tension forces
  • Familiarity with kinematic equations
  • Concept of massless ropes in physics
  • Study the principles of tension in pulley systems
  • Learn about the implications of massless ropes in dynamics
  • Explore advanced topics in systems of equations for multiple bodies
  • Investigate the effects of varying mass on acceleration in pulley systems
Students and educators in physics, particularly those focusing on mechanics and dynamics, as well as anyone interested in understanding the behavior of pulley systems under external forces.
Hannisch
P is a pulley with neglectable mass which is being affected by an external force F. Determine the accelerations of P, m and M.
I've got a picture, but it goes something like this:
There's a pulley and from it (on each side) there are two masses hanging. On the left is m and on the right is M. The force F is from the centre of the pulley and is pointing straight up. (I hope you understand what I mean.)
And it's also assumed that the rope is massless.
F = ma
There are only forces in the y-direction and I'm using up as the positive axis.
m: T - mg = mam
M: T - Mg = MaM
And I know that since the pulley is massless (or can be considered as such) the forces on it need to balance out or it'd be accelerating with infinite acceleration. The forces acting on it are F and 2T, tension from each of the sides.
That means that T = ½F and:
½F - mg = mam
am = ½(F/m) - g
and doing the same for M I get:
aM = ½(F/M) - g
This is stated as correct in my book. My problem is the acceleration of the pulley - I think I'm not seeing something.
Because for some reason (this I can see from the answer that is supposed to be correct) aP = ½am + ½aM
Why exactly is that? Is it because the tension from the rope is half that of the force? I'm a bit confused and I don't want to guess a reason, because that's not going to be so good if I'm not right..
Ah, I'll be thankful for any help :)
- Hanna
If the 2 weights are different are they moving?
½F - mg = mam
am = ½(F/m) - g
aM = ½(F/M) - g
T = F1+F2 =F1/2+F1/2=F for a start. But is the tension necesarry?
I guess they're different (it doesn't say that they're the same and the question clearly differentiates them), so I'd say they probably are moving relative to each other.
Otherwise their acceleration would be the same as that of the pulley, right?
Why wouldn't the tension be necessary? It's the only force affecting the masses up and the only force affecting the pulley down.
And I don't agree that T = F. I definitely don't, since there's tension from both sides of the pulley and that means that 2T = F.
Hint: I think you will have to use the fact that the rope has a constant length, and the pulley will keep it tight all through the movement. So the pulley has to move at some acceleration related to the accelerations of the masses.
Just to clarify: I agree with everything you have done in the first post, but I think you need to use what I wrote above to derive the movement of the pulley.
Good luck!
Torquil
Torquil: That makes a lot of sense. Since the tension is affecting the pulley equally on both sides, I guess that means it would have the half the acceleration of m and half that of M. Thanks!
My approach works just as well, as I see now.
Anyway if the 2 masses are equal then aM=am=aP=F/(m+M)
But as the masses are different then the smaller one will be accelerated faster then the pulley and the other slower. The pulley will be accelerated faster then in the previous case.
  • · Replies 22 ·
  • · Replies 18 ·
  • · Replies 17 ·
  • · Replies 102 ·
