Acceleration versus time graph
When an object is thrown upwards, its acceleration is negative until it reaches maximum height, after which it continues to accelerate downwards towards Earth. The acceleration versus time graph for this motion will be a straight line parallel to the x-axis on the negative side of the y-axis. While the positive and negative values are a matter of convention, the graph remains linear in this context. However, at significant altitudes, the Inverse Square Law affects the acceleration, causing the line to dip towards the x-axis. Understanding these principles is crucial for accurately analyzing motion in physics.
kaaira
when we throw an object upwards its accelaration is negative and after it reaches the maximum height it comes back to us and during that period it has its accelaration still pointing toward the earth. so does that mean that when we draw a accn time graph, for a body thrown up reaching maximum height and coming back to us, will be a straight line parallel to x-axis on the negative side of y?
The positive/negative is somewhat of a choice (/convention) but a straight line, yes.
If you go a really long way up, the Inverse Square Law will start to kick in significantly and the straight line will start to dip towards the 'x axis'.
Good point. Thanks for that addition. I'm used to thinking in terms of problems that talk about something going up for maybe 100 feet.
Well, the radius of curvature of the Earth's surface is pretty massive by architectural and aeronautical standards. :D
I built a device designed to brake angular velocity which seems to work based on below, i used a flexible shaft that could bow up and down so i could visually see what was happening for the prototypes. If you spin two wheels in opposite directions each with a magnitude of angular momentum L on a rigid shaft (equal magnitude opposite directions), then rotate the shaft at 90 degrees to the momentum vectors at constant angular velocity omega, then the resulting torques oppose each other...
  • · Replies 49 ·
  • · Replies 17 ·
13K
  • · Replies 20 ·
