Achieving the speed of light at the end of a whip
The discussion centers around the theoretical possibility of the tip of a whip achieving the speed of light, exploring the physics of whip dynamics, acceleration, and the implications of relativistic mechanics. Participants examine the mechanics involved in whip cracking, the role of material properties, and the nature of wave propagation in this context.
  • One participant questions if there is a consistent equation to calculate the speed of the whip's tip, suggesting that with enough length and power, it might reach the speed of light without infinite energy.
  • Another participant asserts that the motion of the whip's tip is governed by relativistic mechanics, indicating it cannot achieve the speed of light.
  • A later reply discusses the concept of phase velocity, noting that superluminal phase velocity does not violate special relativity as it carries no energy.
  • Several participants mention that the whip's tip must reach twice the speed of sound to create a crack, with one explaining the mechanics of how energy and momentum conservation allows the wave to accelerate as it travels down the whip.
  • One participant introduces a hypothetical scenario involving a neutron star to suggest that under certain conditions, the speed of the whip tip could exceed the speed of light, but still not outpace nearby light.
  • Another participant reflects on the potential for towels to produce a sonic boom when snapped, questioning the mechanics involved without a loop.
  • There are discussions about the differences between the whip and towel mechanics, with some participants expressing uncertainty about the specific types of loops involved in whip dynamics.
  • One participant speculates about calculating gamma factors for a whip in a relativistic scenario, though another advises against it.
  • Concerns are raised about the limitations of Newtonian equations in this context, with a suggestion that applying such equations could yield misleading results regarding speeds exceeding light.
Participants express a range of views, with some agreeing on the impossibility of achieving light speed with a whip, while others explore hypothetical scenarios and mechanics that suggest different outcomes. The discussion remains unresolved regarding the feasibility of reaching light speed and the specific mechanics involved.
Participants note that the material of the whip is not a factor in achieving light speed, as no material can withstand such conditions. There are also discussions about the assumptions underlying the mechanics of whip cracking and the implications of relativistic effects.
This discussion may be of interest to those studying physics, particularly in the areas of mechanics, wave propagation, and relativity, as well as enthusiasts of practical applications of physics in everyday objects like whips and towels.
idktbh1
Is there a equation for the speed at the end of the whip.
is there a consistent way to calculate how fast the tip of the whip will be including constant velocity and trajectory or is it chaotic.
Im new to physics and had a thought that with enough legnth and power a wiphs end colud reach the speed of light without using infinite energy... i don't know if that's the case . I am very invested in this any help wolud be appreciated!My logic is that we use little energy to brake the sound barrier with a whip that it colud be possible to reach the speed of light.
The material of the whip is not a factor. Its ruled out because no material can withstand the speed of light and bend like a whip.
Im just looking for theroetical evidance for this!
Science news on Phys.org
The end of an object is accelerated by the part of the object next to it. If you focus on the end of a whip, its motion is governed by the laws of relativistic mechanics and cannot achieve the speed of light. There is no fundamental difference between the end of a whip and any other object.
this is very demotivating but thank you very much !
All is not lost. There is still some hope.
When a wavefront crosses or is reflected by a line, the locus of the point of contact of wavefront and line, moves at a speed between that of the wavefront and infinity.
https://en.wikipedia.org/wiki/Matter_wave#Phase_velocity
"The superluminal phase velocity does not violate special relativity, because phase propagation carries no energy".
Just for info, the material at the end of the whip needs to reach twice the speed of sound in order for the 'crack' to occur.
PeroK's reply is accurate. Even given a hypothetical material of infinite strength (something physics forbids), no amount of energy could move any part of it locally at light speed. I say locally because plenty of things move faster than light non-locally. A neutrino passes between Alpha-Centauri and here at possibly faster than light as measured by either us or them, but not as measured by something in the current proximity of the neutrino. The difference is that we're all using different clocks that run at different rates due to differences in the gravitational potential of each observation point.
So with enough energy and a deep enough gravity well for your observation point (lawn-chair on a neutron star seems like a good spot, don't forget the ice tea), the speed of the whip tip can indeed exceed c, but will still not outpace nearby light moving in the same direction.
Finding out news things shouldn't be 'demotivating'. Science is a journey, littered with occasions when one finds out one is wrong. Accepting that you need to modify your view according to evidence is healthy.
Mass'y material can't do light speed.
Better now than when you've spent a fortune trying to develop a whip that can't work.
Also : spellcheck, spellcheck, spellcheck, spellcheck...
Don't leave us hanging... why ?
The technique seems to be to form a loop in the whip and propagate that down the ever-thinning length of the thing. So conservation of energy and momentum has the loop 'wave' moving faster and faster as the mass density of the whip goes down towards the end. The tiny sonic boom occurs if the loop can be made to move at supersonic speeds. Since it is a loop, the top of it moves at twice the speed just like the top of the wheel of a car moves at twice the speed of the car. A car does not make a sonic boom at 650 km/hr even though the top of its wheels are moving at supersonic speeds.
Now I am wondering if the ritual of snapping of towels in the gym was producing a sonic boom.
There was evidently no loop in the towel.
"Evidently"? You would need a slomo camera, close up, to observe the shape at the end of a towel. Afair, the effect was best with the towel operated 'diagonally', with a corner at the end; ideal for producing a small loop and a high speed. Ahhh those were the days.
EDIT: PS, I just remembered the same sort of horseplay with my sons in the kitchen when they should have been drying dishes.
sophiecentaur said:
"Evidently"?
Not the same type of loop as the 'one coil loop' ( it is kind of like a twist was put into the whip somehow ) that travels down the bullwhip that they use to analyse the bullwhip - not sure if every bullwhip user produces that type, but they ( who is they ? and why ) presume so.
The towel loop would not have that type of coil - it would be simply a halved towel where one end unfurls, and the tip of that end accelerates and the length common to the tip shortens.
So if Indiana Jones is standing on top of a train moving at 0.999999999999999999999C, calculate the gamma factors along the length of his whip from the frame of reference of his intended target bad guy standing beside the track
(actually please don't)
I made an assumption that the shape of the wave traveling along the whip / towel would be a simple transverse semi-loop (U shape). If anything else was meant then I would have expected a diagram as explanation. A photo image of that would constitute evidence.
idktbh1 said:
Is there a equation for the speed at the end of the whip?
If such an equation exists, it would likely be Newtonian and ignore relativity. Getting a whip to move fast enough that relativity becomes relevant sounds... unlikely. Putting big numbers into a Newtonian equation might produce an answer faster than light. But as others here have said, what would really happen is that the energy you put into the whip would just go into making it's effective mass higher, and then tearing the whip apart.
Nice video of a whip in slow motion :
  • · Replies 21 ·
  • · Replies 17 ·
  • · Replies 44 ·
15K
  • · Replies 54 ·
  • · Replies 36 ·
28K
11K
