High School Why is the reaction force different when passing through different materials?
  • Thread starter Thread starter Kaneki123
The discussion centers on the differences in reaction forces experienced by a body A as it passes through various materials: air, water, and solid objects. It is established that the force applied by body A is not constant across these scenarios due to the structural differences of the materials. In air, body A encounters fewer interconnected molecules, allowing it to pass through with decreased velocity. In contrast, when encountering a solid, the rigid structure prevents passage, resulting in a significantly higher reaction force. The principles of Newton's Third Law are emphasized, highlighting that the actual value of the force varies based on the material's properties and the context of the interaction.
  • Understanding of Newton's Third Law of Motion
  • Basic knowledge of material properties (solid, liquid, gas)
  • Familiarity with concepts of force and momentum
  • Awareness of equilibrium forces in physics
  • Explore the concept of material rigidity and its impact on force transmission
  • Study the relationship between force, mass, and acceleration in different mediums
  • Investigate examples of action-reaction pairs in real-world scenarios
  • Learn about the dynamics of forces in equilibrium situations
Physics students, educators, and anyone interested in understanding the principles of mechanics and material interactions in various environments.
Kaneki123
I am having a little bit trouble with understanding action-reaction...I am going to discuss three scenarios...Please tell me about the action-reaction in them
Okay...let's assume about a body A that is positively accelerated upto a certain velocity...This body A is in an isolated system...
Ist: If this body A enters in a field of air, it will actually PASS THROUGH (ofcourse with some decreased velocity)
2nd: If the body A enters a field of water, again it will pass through(although with an even more decreased velcity than that in Ist)
3rd:If the body A tries to go through solid( let's say wall or table), it will not pass through...
My question is that, in all of these scenarios,the body A will come in contact with some molecules or particles and in all cases the force it applies on these molecules is same...(So reaction will also be same)...So why is that the body A can pass through less molecule area(air) and will not pass through more molecule area(solid)?
The force that the body applies will not be the same in the three cases.
Can you please elaborate as to why the force will not be same? Is it because less number of molecules?
It is not the number of molecules exactly. It is the way they are structured. A solid is not simply a very dense gas. It is rigid. The molecules are interconnected. If you push on one side, all the other molecules move as well. That means that as you push on one face of a solid, that face cannot simply move out of your way. It will stay right there. Think of running head first into a sheet of tissue paper or into a brick wall. Which one involves more force on your nose?
The force is equal to a change in momentum over time. Which has more momentum: moving air, moving water, moving a table?
Okay...Let's take another example...Consider a person standing on a thin wooden plank...The amount of force by the person on the plank is equal to that person's weight...But that plank pulls down until it can support the person...So at first, when the person just mounted on the plank, when the plank is just going to pull down, is the amount of force applied by the person on the plank at that specific time actually lesser than the actual force? (the total weight of that person)...So that when the plank is finally pulled down, that's the moment the person's force on the plank is 'maximum'(the actual weight of person)?...I hope you understand the confusion...
When the person accelerates down, the force is less than the weight. When it accelerates up, it's more than the weight.
I think this is getting away from what "Action - Reaction Pairs" (or Newtons Third Law pairs) is all about. Whatever force is acting on an object, there is another force (equal and opposite) acting on whatever it is that is causing that force. The actual value of the force will depend on the circumstances (as in the three cases that were discussed originally but the same principle applies. The multiple forces which are involved in equilibrium situations are an entirely different matter and all of the forces acting in that case will consist of third law pairs - tension on the tether / gravitational pull / rocket engine thrust etc will all be acting on the fixing point, the Earth and the particles that the engine is ejecting as well as on the rocket. Whether or not you have equilibrium forces on the rocket is a different issue.
13K
  • · Replies 18 ·
11K
  • · Replies 20 ·
