Active force of spring on mass (D'alemberts)
buildingblocs
I am trying to understand the effect that eliminating the mass m1 (m1 = 0) has on the active forces (Fa). I have gone through a scenario where m1 is taken into consideration (refer to uploaded images). The active force on m1 is from the spring and does not have m1 in the expression (Fs1 = (l-r)k), so I did not think that there would be any change. However the set of D'alemberts reduces if m1 is eliminated, so how does active force from the spring effect the remaining equation of motion.
If more info or clearing up is required please do not hesitate to ask. Any help would be much appreciated.
Cheers.
  • Handwritten derivation on lined paper: a sketch of a spring-pendulum system with mass m1 on a horizontal rail and mass m2 on a rod at angle θ, with independent variables (r, θ), position vectors r1 and r2, and velocity and Jacobian matrix expressions.
  • Handwritten derivation on lined paper: acceleration vector expressions in polar coordinates with r and theta terms, then a D'Alembert equation line for active forces Fa1 and Fa2 with spring force (l-r)k and gravity term -mgj.
Can you write it up there? The attachments are hard to read and their wrong orientation does not help either.
I don't understand what you want to test/show.
The force of the spring at a specific location does not depend on the mass, but the equations of motion certainly do because acceleration is force divided by mass. This also means you cannot expect a physical answer if you set the mass to zero. If you have a spring without mass attached, you still have the mass of the spring (which is often neglected).
Diagram of a spring-mass-pendulum system: a block (Mass 1) on a frictionless surface attached to a spring with constant k, and a pendulum of Mass 2 hanging from the block at angle θ, with q marking the block's horizontal displacement.
figure1.
In figure1, the generalised variables are q and θ, and there are two masses (mass of the spring is neglected). The active forces are Fa1 = Fspring1 (horizontal direction) and Fa2 = Fweight (vertical direction). Therefore it follows that there should be four parts for the equations of motion:
(Fa1 - m1a)∂r1/∂q + (Fa1 - m1a)∂r1/∂θ + (Fa2 - m2a)∂r2/∂q + (Fa2 - m2a)∂r2/∂θ = 0 [eq1]
this is simplified to:
(Fa1 - m1a)∂r1/∂q + (Fa2 - m2a)∂r2/∂q + (Fa2 - m2a)∂r2/∂θ = 0 [eq2]
as ∂r1/∂θ=0
My query is what happens when m1 is eliminated from the system (m1 = 0)
The is now two generalised variable and only one mass:
[eq3]
Free-body style diagram of a pendulum on a frictionless surface: a block labelled Mass 1 with coordinate q sliding on the surface, and a rod from its centre hanging at angle θ to a ball labelled Mass 2.
figure 2.
Now consider figure2 (Spring is removed and m1=0)
The equation of motion of system in figure2 is the same as that for eq3, where the spring was included. This intuitively does not appear correct, and I wish to understand how to take into account the effect of spring on the remaining system when m1 =0;
If you set m1 to zero, you cannot ignore the forces on r1 - they are still part of the mechanics. The only difference is the exact cancellation of the force from the spring and the horizontal component of the force in the beam (the experiment does not work properly with a string of course)
