Cyclic Coordinates are linear in time (proof)?
  • Level: Graduate
  • Thread starter PhDeezNutz
1 reply · 79 views · last reply
PhDeezNutz
TL;DR
I want to prove that if all coordinates are cyclic then all coordinates are linear in time from Hamilton's Equations of Motion and the Euler Lagrange Equation. I want to do this with generalized momenta as opposed to mechanical momenta....where the conclusion is trivially true p = mv.
Motivated by the first page of these notes: https://ocw.mit.edu/courses/8-09-cl...a346a0868efb7430582c_MIT8_09F14_Chapter_4.pdf
Theorem: If all coordinates are cyclic (##\dot{p}_i = 0 \Rightarrow p_i = \alpha_i \text{ (nonzero constant)}##) then all coordinates are linear in time ##q_i = \omega_i t + \delta_i##
Background Information:
1) Einstein notation is used (Double identical subscripts imply a sum)
2) Euler Lagrange Equation
$$\frac{d}{dt} \left( \frac{\partial L}{\partial \dot{q}_i}\right) - \frac{\partial L}{\partial q_i} = 0 \tag{1}$$
where
$$p_i = \frac{\partial L}{\partial \dot{q}_i} \text{ so } \dot{p}_i = \frac{d}{dt} \left( \frac{\partial L}{\partial \dot{q}_i}\right) \tag{2}$$
3) Hamiltonian Definition and Hamilton's Equations of Motion
$$H \left( q_i, p_i \right) = p_i \dot{q}_i - L \left( q_i, \dot{q}_i \right) \tag{3}$$
where of course the Lagrangian is eventually expressed in terms of ##q_i## and ##p_i##. Hamilton's Equations of motion are
$$\dot{q}_i = \frac{\partial H}{\partial p_i} \tag{4}$$
$$\dot{p}_i = - \frac{\partial H}{\partial q_i} \tag{5}$$
Now for the actual proof:
Proof:
Plug (4) into (3) and ##H(q_i, p_i)## becomes
$$H(q_i,p_i) = p_i \frac{\partial H}{\partial p_i} - L \left(q_i, \dot{q}_i \right) \tag{6} $$
Take the total differential of both sides in ##(6)##
$$\frac{\partial H}{\partial q_i} dq_i + \frac{\partial H}{\partial p_i} dp_i = \frac{\partial H}{\partial p_i} dp_i + p_i d\left( \frac{\partial H}{\partial p_i} \right) - \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{7} $$
Now to expand ##p_i d\left( \frac{\partial H}{\partial p_i} \right)##
$$ \frac{\partial H}{\partial q_i} dq_i + \frac{\partial H}{\partial p_i} dp_i = \frac{\partial H}{\partial p_i} dp_i + p_i \frac{\partial^2 H}{\partial p_i^2} dp_i + p_i \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{8} $$
Some of these terms cancel out by algebra and some of these terms are zero by the theorem assumptions
1) ##\frac{\partial H}{\partial p_i} dp_i## cancels out because it is on both sides
$$ \frac{\partial H}{\partial q_i} dq_i + \cancel{\frac{\partial H}{\partial p_i} dp_i} = \cancel{\frac{\partial H}{\partial p_i} dp_i } + p_i \frac{\partial^2 H}{\partial p_i^2} dp_i + p_i \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{9} $$
$$ \frac{\partial H}{\partial q_i} dq_i =
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{10}$$
2) ##\frac{\partial H}{\partial q_i} dq_i = - \dot{p}_i dq_i## by (5) and ##\dot{p}_i = 0## by assumption of theorem. So ##\frac{\partial H}{\partial q_i} dq_i =0##
$$ \cancelto{0}{\frac{\partial H}{\partial q_i} dq_i} =
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{11}$$
$$0 =
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{12}$$
3) ##dp_i = 0## by assumption since ##p_i = \alpha_i## (nonzero constant)
$$0 =
\cancelto{0}{p_i \frac{\partial^2 H}{\partial p_i^2} dp_i} + p_i \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{13}$$
$$0 =
- \frac{\partial L}{\partial q_i} dq_i - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{14}$$
4) By definition ##\dot{p}_i = \frac{\partial L}{\partial q_i}## and by assumption of the theorem this quantity is 0
$$0 =
- \cancelto{0}{\frac{\partial L}{\partial q_i} dq_i} - \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{15}$$
$$0 =
- \frac{\partial L}{\partial \dot{q}_i} d\dot{q}_i \tag{16}$$
5) Again by assumption ##p_i = \frac{\partial L}{\partial \dot{q}_i}= \alpha_i ## (nonzero constant)
$$0 =
\alpha_i \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- \alpha_i d\dot{q}_i \tag{17}$$
6) So we finally have
$$\alpha_i \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- \alpha_i d\dot{q}_i = 0 \tag{18}$$
7) Divide by ##\alpha_i## just to make things cleaner
$$ \frac{\partial^2 H}{\partial q_i \partial p_i} dq_i
- d\dot{q}_i = 0 \tag{19}$$
8) Let's permute the order of partial derivatives
$$ \frac{\partial}{\partial p_i} \left( \frac{\partial H}{\partial q_i} \right) dq_i
- d\dot{q}_i = 0 \tag{20}$$
9) By definition of conjugate momentum ##\dot{p}_i = - \frac{\partial H}{\partial q_i}## which is zero by assumption of the theorem
$$ \frac{\partial}{\partial p_i} \cancelto{\dot{p}_i = 0}{\left( \frac{\partial H}{\partial q_i} \right)} dq_i
- d\dot{q}_i = 0 \tag{21}$$
10) So
$$ d\dot{q}_i = 0 \Rightarrow \dot{q}_i = \omega_{i} \Rightarrow q_i = \omega_i t + \delta_i \tag{22}$$
where of course ##\omega_i## is a constant.
Is my proof valid?
Did any assumptions creep in?
Did I miss any edge cases?
Did i lose any generality?
I look forward to your feedback.
It seems the proof is way simpler.
If ##H## is cyclic in all ##q_i## giving ##\dot{p}_i=0## for all ##i##, then, assuming ##H## has no explicit time dependence, it is clear ##H=H(p_i)## so that:
$$\dot{q}_i=\frac{\partial H}{\partial p_i}=\omega_i(\alpha_1,...,\alpha_n)$$
And ##\omega_i## are all constant functions. From which integration immediately yields your solution.
