Adding a variable to a Lagrangian
  • Thread starter Thread starter MyoPhilosopher
    Lagrangian Variable
7 replies · 1K views · last reply
MyoPhilosopher
$$ L = m\vec{\dot r}$$
Would the following: $$ L = m(\vec{\dot r + \vec v})$$ (constant velocity added to above eq.)
lead to equivalent euler-lagrange equations due to the fact that the ratio of T and V is unaffected by an increase in constant velocity?
And would this be an example of energy conservation?
##L## should have dimensions of energy, not momentum.
##L## can be expressed in terms of ##T## and ##V##.
Even more importantly, it should be a scalar and not a vector.
actually the Lagrange equations do not care even if you add
$$\frac{d}{dt}f(t,\boldsymbol r)=\frac{\partial f}{\partial t }+\Big(\frac{\partial f}{\partial \boldsymbol r},\boldsymbol{\dot r}\Big)$$
What exactly does adding constant velocity do? Would is simply increase the r_dot vectors equally and therefore not affect the equations of motion?
I should have squared my second term, would this be appropriate $$ L = {m(\vec{\dot r + \vec v})}^2$$
Adding a constant velocity is effectively doing a Galilean boost, i.e., transforming to a coordinate system that moves at constant velocity relative to your original coordinate system.
The difference between the Lagrangians is ##m (\vec v \cdot \dot{\vec r} + v^2/2) = \frac d{dt}(\vec v \cdot \vec r + v^2 t/2)##. Thus, as per #4, the equations of motion are invariant under this transformation (which actually is the transformation ##\vec r \to \vec r + \vec v t##).
Ahhh thank you that clarified it elegantly!
