Adding Normal Forces for Net Force Calculation
22 replies · 5K views · last reply
Asuncion
How do you add the normal forces together after you derive the x and y component?
Normal force = m*g*sinθ (y component)
Normal force = m*g *cosθ (x- component)
Bottom line is I'm trying to get the Net Force.
Net force= mass of the object + normal force - kinetic friction force.
Welcome to PF!
Hi Asuncion! Welcome to PF! :wink:
(btw, mass isn't a force, you mean weight :wink:)
(Are you talking about a body moving along a slope?)
You don't "add the normal forces together",
you add the component of one force to the same components of the other forces (in the same direction)
No, those are the components of the weight, not of the normal force. :smile:
I thought
W (weight)= mg
N (normal force)=Wcosθ
Fk(kinetic friction) = μkN
Here's the data given:
mass= 10kg textbook
μk = 0.3
θ= 30
g = 9.8 m/s2
Find net forces. So I add the Weight, and Normal Forces together then subtract the kinetic friction force even though it lies on the positive x axis. Hummm...
Asuncion said:
I thought
W (weight)= mg
Yes, that's correct. :smile:
(the last line is a vector equation)
That wasn't correct.
That, I didn't really understand. :confused:
I'm not following you.
Add the x-components of all the forces, that gives you the net force (you know its y-component is zero, don't you?) …
what do you get? :smile:​
Hey Tim! Thanks for your help. So here's what I've come up with after 3 hours of surfing different physics sites.
Incline plane problems are more complex than other force problems because the forces acting on the object on the incline plane are not perpendicular. Therefore, components must be used (quote from Mr. fizix site.)
Picture a box on a incline plane. W is the resultant vector. Therefore, you add the Wx and Wy components together.
W= Wx + Wy
Wx = Wsinθ
Wy = Wcosθ
I knew I must add the components together...I should have applied the basic vector addition. I was getting hung up over the "name"...So regardless if it's friction, weight, normal etc. As long as you have θ you can find the X and Y components...I'm learn'in LOL...anyways so for the 100 kg small crate I got a net force of 1571. (pretty high though..hummm) and for the 10 kg textbook I got 154N, both having a acceleration of 15m/s2. Am I right? :/
Sorry if I confused you I got the Normal force and Weight Force equations confused. Original Quote "How do you add the normal forces together after you derive the x and y component?" Now I know, add the Weight components not the Normal Force components.
sorry, you've lost me :confused:
how did you get those figures?​
Sorry. I promise I'm not trying to confuse you on purpose. I had to re-calculate. Here's what I came up with.
m=100 kg
Fn= 100 *9.8cos30=845 N
Fw= 1339N
W= 100 *9.8=980N
Wx= 980cos30
Wy = 980sin30
(Add components together Fw=1339 N.)
Fk =.3(845N)= 254N
Fnet = Fn+ Fw - Fk=1930N
a=acceleration
a=19.3 m/s^2.
Wait! Shouldn't the g be -g for the Fn equation because normal force is pointing upward against gravity? hummm... hope I didn't confuse u even more :/
(try using the X2 button just above the Reply box :wink:)
Asuncion said:
Wx= 980cos30
Wy = 980sin30
ah I see!
no that's rubbish :redface:
you can't add Wx to Wy
you can't add any x-component to any y-component
you can add all the x-components together
you can add all the y-components together
that's how vectors work …
when you add them, you add the components (separately), not the magnitudes
Okay Tim, help me out here. Honestly I have already turned in this lab, BUT I need to know the right way to solve the problem. It's almost like I'm about to breakthrough physics! I'm excited. So can you help me out alittle here?
Tim, How would you find the all the kinetic friction force, nornal, force, weight force, all finally the net force? and the acceleration? I ask because This information will be needed to solve the more complicated---deriving a formula that shows a relationship between the mass of an object and how far it travels off the end of the ramp (this is the ultimate tricky part.)
And as I become more familiar with physics this is what's it all about. Adjusting the 3 main formulas to derive a New formula! Am I right! Kinda like solving in "more ways than one" anyways, how would you create a formula that shows a relationship between the mass of an object and how far it travels off the end of the ramp? Thanks Tim!
Oh yeah one more thing to address the "no adding x and y component vectors"...
I wish I could attach the diagram I drew. :rolleyes: don't know how to do that, but any hoos, I was treating the weight force vector like the resultant vector. Therefore, according to pythagorean theorem you can add them together...hold that thought...the normal vector and the friction vector are at a 90° angle does that matter! Okay I'm officially lost.
I'm going to start at the beginning to keep everything clear:
An object of mass m sitting on a plane inclined at angle [itex]\theta[/itex]. In this situation we have to consider both the force of gravity and the normal force; however, the mass is sliding down the plane (if the mass is sliding up the plane a similar method follows) and so we have to consider the kinetic force of friction. So we have three different forces to consider in this problem.
When solving inclined plane problems I find it easiest to think of vector components in terms of components parallel and perpendicular to the plane (you can use regular x- and y- if you're comfortable; you can actually use any co-ordinate system in which the axis are perpendicular but the different values for angles might be confusing; either way, I will stick to components parallel and perpendicular to the plane).
I know this may be difficult to visualize, so if you're having trouble try drawing a diagram (an FBD) to help.
The force of gravity points directly downwards. This force can be "broken up" into components such that you will have a parallel and perpendicular component of gravity. The perpendicualr component of gravity is the component Ipushing the mass into the plane; the parallel component is the component pushing the mass down the plane (this is what cause the mass to slide down the plane). So we can write the following:
[itex]F_{g||} = mgsin\theta[/itex]
[itex]F_{g\perp} = mgcos\theta[/itex]
Convince yourself of this by drawing an FBD and considering only the force of gravity. Use similar triangles to show that [itex]\theta[/itex] is the angle of inclination.
Note that these components will satisfy the Pythagorean Theorem such that:
[itex]F_{g} ^{2} = F_{g||} ^{2} + F_{g\perp} ^{2}[/itex]Next consider the normal force. The normal force must act entirely perpendicular to the plane (there is no component of the normal force parallel to the plane); this may not always be true, but in this question it is (and pretty much every question I've dealt with. Explain why the normal force must act perpendicular to the plane. (Hint: Consider what would happen physically in the direction perpendicualr to the plane if the normal force was not equal to the perpendicular component of the gravitational force.)
You can write:
N = N[itex]_{\perp} = mgcos\theta[/itex]
Lastly, consider the force of kinetic friction. The force of kinetic friction always acts opposite to the direction of motion; if the mass is sliding down the plane the force of kinetic friction points up the plane. What is the expression for the force of kinetic riction?Now we have all the information we need. You have found expressions for 3 forces and have written one of those forces in terms of its compoents so we have 4 expressions. If we perform a net force balance in both the direction perpendicular and parallel to the plane equating the sum of the forces to ma you should be able to solve. Perform a force balance in both the perpendicualr and parallel directions.
Does this make sense? Please ask if you have any questions (if anyone notices a mistake, please correct me; I was a bit sloppy in terms of positive and negative directions parallel to the plane).Also, it helps to solve everything in terms of variables instead of pluggin numbers so you can see what your final equation looks like. Once you have an equation you can check its units to see if what you've done is (probably) correct.
Hi Asuncion! :smile:
Asuncion said:
Tim, How would you find the all the kinetic friction force, nornal, force, weight force, all finally the net force? and the acceleration? …
you start with whatever the question gives you, and then apply the formulas
if a formula says eg F = ma, sometimes you know F and m and you have to find a, sometimes you know a and m and you have to find F, sometimes you know F and a and you have to find m :wink:
if there's more than one formula to use, you just have to choose the correct order to link them all together so that you keep using what you already know, and finding something to use in the next formula
that would be conservation of energy … better wait until you do that in class! :wink:
it depends what you mean by "add"
scalars (ie, ordinary numbers) add like scalars
vectors add like vectors (as in a vector triangle or vector parallelogram)
for three vectors A B and C, you can have a vector addition equation A + B = C
or three scalar addition equations
Ax + Bx = Cx
Ay + By = Cy
Az + Bz = Cz​
and you can even add Axi Ayj and Azk to give the resultant A (which you're calling pythagorean addition) :smile:
"Conservation of Energy"--yeah might want to wait on this tuff cookie.
Okay guys let's get this right. There's an object (small crate) that's on an incline plane that's at a 30° angle. The object (small crate) weighs 100 kg. The incline is made of wood so the kinetic friction is 0.3. Okay. With that given information I am going to find the normal force. The kinetic friction force and the gravity (a.k.a weight) force. Okay let's began.
Normal force Fn=m*gcosθ
Fn=100 kg*9.8 m/s^2cos30=848N
Friction Force Fk=μn
Fk=0.3*848N=255N
Here we go again..
Weight force=Wsinθ
Fw=980sin30=490N
Now let's add'em Up..
Fnet = Fn+ Fw - Fk=848N + 490N - 255N= 1083N
Please tell me I did this right...If not just show me how please.
Oops I left out how I got the weight.
W=m*g
W=100 kg * 9.8 m/s^2=980N
Oh and I only used the Wy component of weight. Not the Wx component of weight. Thanks. Again if I didn't do this right just show me how. Thanks guys.
Can I use microsft to draw FBD? or is there another program/software you can recommend? thanks ;)
dunno
No! you've done it again! :redface: …
you've added perpendicular forces.​
That equation is for the x-components only, there's no normal force there.
Useful tip:
Stop using "F" for force …
haven't you noticed, they're all forces! :rolleyes:​
Use "N" for normal force,"W" for the weight, "F" for the friction force,etc
And then you can write eg Wx + Fx = 0 …
that way you won't get y components in an x equation! :wink:
Try again. :smile:​
So are you saying that the net force only consist of the forces that's parallel to the x axis. If so than the normal force and weight force cancel out and that just leaves the kinetic force. Am I right? If so, the net force=-255N. it's negative because its going in the opposite direction.
Have you drawn a diagram? :confused:
How can the normal force have anything to do with the x direction?
Thanks Guys! Wow, reading the thread now its a piece of cake, but at the time it all blew right over my head! LOL
I don't know if this has been mentioned, but in problems such as this it greatly helps to rotate the xy coordinates so that x is parallel with the slope. That way the friction force is negative along the x axis, the normal force is positive along the y-axis and all you have to decompose is gravity.
