Adding primitive roots of unity
13 replies · 3K views
Artusartos
I was trying to figure out whether or not ##\zeta_5 + \zeta_5^2## and ##\zeta_5^2 + \zeta_5^3## were complex (where ##\zeta_5## is the fifth primitive root of unity).
##\zeta_5 + \zeta_5^2 = \cos(2\pi/5) + i\sin(2\pi/5) + (\cos(2\pi/5) + i\sin(2\pi/5))^2 = \cos(2\pi/5) + i\sin(2\pi/5) + \cos(4\pi/5) + i\sin(4\pi/5)##.
Since ##i\sin(2\pi/5)## and ##i\sin(4\pi/5)## do not cancel out each other, ##\zeta_5 + \zeta_5^2## must be complex, right?
##\zeta_5^2 + \zeta_5^3 = (\cos(2\pi/5) + i\sin(2\pi/5))^2 + (\cos(2\pi/5) + i\sin(2\pi/5))^3 = \cos(4\pi/5) + i\sin(4\pi/5) + \cos(6\pi/5) + i\sin(6\pi/5)##
But again, the complex numbers don't cancel out each other, right?
draw an argand diagram! :rolleyes:
(ie mark them out as vectors on a unit circle)
##\bar{\zeta_n}\zeta_n = 1##, so ##\bar{\zeta_n} = 1/\zeta_n##. Suppose ##\zeta_n^r+\zeta_n^s## is real. What can you deduce about r+s?
When I draw a diagram, I need to go three times the angle of ##\zeta_5## for ##\zeta_5+\zeta_5^2##, and so I end up in quadrant three, right? So it is not real.
But for ##\zeta_5^2 + \zeta_5^3## or ##\zeta_5+\zeta_5^4## we need to go 2+3=1+4=5 times the angle of ##\zeta_5##, and so we will be going all the way and end up back in 1, right? So it must be real.
Do you think that's correct?
Hi Artusartos! :smile:
I'm not sure what you're doing there (looks more like multiplication than addition :confused:).
Draw the vectors OB and OC (for ##\zeta_5^2## and ##\zeta_5^3##), and then use the parallelogram law to add them …
what do you see? :wink:​
Well, that looks like it's in the second quaderant, right?
what's in the second quadrant? :confused:
do you know the parallelogram law?
you should be seeing two vectors OB and OC, and a parallelogram with BOC on three sides​
Oh I'm sorry. I was looking at ##\zeta_5## instead of ##\zeta_5^2## and ##\zeta_5^2## instead of ##\zeta_5^3##...
So if I look at ##\zeta_5^2 + \zeta_5^3##, then it lies on the x-axis and so the sine is zero and it must be real, right?
yup! :biggrin:
(though it worries me that you add "the sine is zero" …
i see what you mean, but it really has nothing to do with the problem, does it? :wink:)​
tiny-tim said:
yup! :biggrin:
Thanks a lot. :smile:
But I'm not sure why it doesn't have to do with this problem. We want sine to be zero, because it is the complex term in ##\cos(2\pi/n) + i\sin(2\pi/n)##, right?
Artusartos said:
… it is the complex term in ##\cos(2\pi/n) + i\sin(2\pi/n)##, right?
First, you need an "r" there: ##r[\cos(2\pi/n) + i\sin(2\pi/n)]##.
Second, it's much simpler to say that a real number is a complex number x + iy with y = 0 …
and the x + iy form is perfect for addition (of two complex numbers), while the reiθ (polar) form is pretty much useless! :wink:
Seems you didn't like my hint, so I'll take it a bit further:
If ##\zeta_n^r+\zeta_n^s## is real then ##\zeta_n^r+\zeta_n^s = \bar{\zeta_n^r}+\bar{\zeta_n^s} = 1/\zeta_n^r+1/\zeta_n^s##. Multiplying out, ##\zeta_n^{2r+s}+\zeta_n^{r+2s} = \zeta_n^r+\zeta_n^s = \zeta_n^{r+s}(\zeta_n^r+\zeta_n^s)##. Can you take it from there?
Thanks. So if ##\zeta_n^r+\zeta_n^s## is real, then ##r+s## must be a multiple of ##n##.
So now I should prove that ##\zeta_n^r+\zeta_n^s = \bar{\zeta_n^r}+\bar{\zeta_n^s}##, right?
But shouldn't we be proving the converse instead? That if ##r+s## is a multiple of ##n##, then ##\zeta_n^r+\zeta_n^s## must be real?
There is another solution to the equation.
Not sure what you mean. If the sum is real then ##\zeta_n^r+\zeta_n^s = \overline{\zeta_n^r+\zeta_n^s}##, from which the above follows quickly.
It depends. You asked whether a particular sum of powers is real. We've shown that if it is then a certain relationship holds. If the powers do not satisfy that relationship then the sum is not real. If the powers do satisfy it then, yes, there's a bit more work to do, but it's basically running the same argument backwards.
