Adding Radius of Gyration values?
The discussion focuses on calculating the radius of gyration for a tire and wheel assembly. The original poster is unsure if they can simply add the individual radius of gyration values for the tire and rim, as this results in an unrealistic combined value. A response clarifies that the correct approach involves calculating the moment of inertia for each component based on their respective masses and then combining these to find the total radius of gyration. This method ensures that the resulting value remains within the physical constraints of the tire's dimensions. The poster acknowledges the advice and plans to implement the suggested calculations.
Nugget12
Hi There
I am doing a little test program for some tire testing and just need to make sure I am doing something right, I am calculating the radius of gyration of my tire and wheel separately using the formulas from Dunlop http://www.dunlopaircrafttyres.com/tech_support/dunlop-engineering-data.aspx So I have a value of k for the tire and wheel, do I just add those two together to get the combined radius? I do that currently but it leaves me with a value of k that is outside the radius of the tyre, ie for a tire whose diameter is 0.36m I get a k value for the rim of 0.201 and for the tire of 0.239 so combined it comes to 0.44 which feels wrong to me. Can anyone see where I am going wrong?
Chris
Nugget12 said:
Hi Ther
Chris
The gyradius r is based on the mass of a rotating object and its moment of inertia about the axis of rotation, such that:
r2 = I / M
where
I - moment of inertia
M - mass of the object
Your tire and wheel probably have two different masses, so the proper calculation would be to convert the gyradius of each component to a moment of inertia, using the correct masses, add the moments together, and then calculate the gyradius of the combined assembly, like so:
Itire = Mtire*rtire2
Iwheel = Mwheel*rwheel2
Itotal = Itire + Iwheel
Mtotal = Mtire + Mwheel
rtotal = (Itotal / Mtotal)1/2
Many thanks for the quick reply, that looks more sensible, will give that a try. Thanks.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
18K
  • · Replies 21 ·
