Adding sin plus cos with fractions containing square roots
To solve the expression sin(pi/3) + cos(pi/6), it is established that sin(pi/3) equals (sqrt(3))/2 and cos(pi/6) also equals (sqrt(3))/2. The addition of these fractions can be simplified by recognizing that they share a common denominator of 2, allowing the numerators to be combined. This results in (sqrt(3))/2 + (sqrt(3))/2 equaling (2*sqrt(3))/2, which simplifies to sqrt(3). The discussion clarifies the correct method for adding fractions with square roots and emphasizes the importance of understanding the properties of square roots in mathematical operations.
teffany
How do I solve:
[sin (pi/3)] + [cos (pi/6)]? <--- "pi" is 3.14...
I think that [sin (pi/3)]= (square root 3) divided by 2
AND that [cos (pi/6)]= (square root 3) divided by 2.
Now I can't remember how to add fractions containing square roots.
My textbook says the answer is: square root 3.
I just have NO IDEA how to get there.
Please help! Thanks in advance.
Sorry... I just read that this forum isn't for getting homework help. But I don't know how to move this post, so if somebody in here could help me, I'd appreciate it.
No worries. You may have noticed that it took only nanoseconds for your post to get moved to Homework Help :-)
Are you allowed to use a calculator, or do you need to use tables, or are you supposed to use some other methods?
Wow... A+ for getting my post the heck out of dodge.
Calculators are permitted; but I can't get mine to cooperate. There is a "Trigonometric Functions of Special Angles" table in our textbook and I see that the sin pi/3 = (square root 3)/2, and that cos pi/6 = (square root 3)/2.
Sine my original post, I converted radians to degrees to see if that would work, and it did... kind of.
For the sin part of the problem, the radians = 60 degrees. The sin of 60 degrees is .8660.
For the cos part of the problem, the radians = 30 degrees. The cos of 30 degrees is .8660.
I realize .8660 + .8660 = 1.732 which is THE SQUARE ROOT OF 3.
But, how am I supposed to know 1.732 = the square root of 3 on my own? (The book says the answer is the square root of 3.)
I'm assuming I went about the problem differently, so I would now like to know how to work it using square roots.
You are going to (or should!) feel very silly about this. You add fractions with square roots the same way you add any fractions: by getting a common denominator. Since you already have a common denominator, 2, you just add the numerators. Or, since the fractions happen to be identical here, use "a+ a= 2a"! What is 2 times sqrt(3)/2?
Could the equation look like this?
sqrt(3)/2 + sqrt(3)/2 = sqrt(6)/2 = sqrt(3)/1 = sqrt(3)
\frac {\sqrt 3} 2 + \frac { \sqrt 3} 2 = \frac { 2 \sqrt 3} 2 = \sqrt 3
It doesn't get any simpler :smile:
Note: what you did was awfully wrong :frown: You can't add square roots this way. Think about it: if sqrt(4) + sqrt(4) = sqrt(8) then 2+2=sqrt(8), or 42=8. Obviously that's wrong.
Oh! I finally get it! Thank you SO MUCH! I have seen the light of adding square roots.
Yes, it is exactly like adding anything else: x/2+ x/2= 2x/2= x no matter what x is.
  • · Replies 21 ·
  • · Replies 21 ·
  • · Replies 22 ·
