What mistake did Mindy make when solving this quadratic equation?
  • Thread starter Thread starter halvizo1031
    Errors Student
Mindy incorrectly solved the quadratic equation (x+4)(x-3)=8 by setting each factor equal to 8, leading her to conclude there was only one solution, x=4. In reality, she missed the second solution, x=11, as she misunderstood the application of the zero product property. Her mistake stems from assuming that if ab=c, then a=c or b=c, which is not valid outside of zero products. This misunderstanding relates to the property of fields and integral domains, specifically the concept of "no zero divisors." Ultimately, her approach resulted in a significant error in identifying all possible solutions.
halvizo1031
Mindy solves the problem (x+4)(x-3)=8 by setting x+4=8 and x-3=8, thereby getting the solutin x=4 from both equations. she checks her answer by substituting x=4 into the original equation and finds that it works. She concludes that this quadratic equation has only one solution. if we check x=-5, it also works. she lost a solution. WHAT MISTAKE DID MINDY MAKE? WHAT MIGHT SHE NOT UNDERSTAND? WHAT PROPERTY OF FIELDS/INTEGRAL DOMAINS IS MINDY'S MISTAKE RELATED TO?
If she were to first FOIL, subtract 8 from both sides, and solve for x, then she would get both solutions. BUT, i am stuck in explaining what she might not understand and what fields/integral domains is her mistake related to...
I'm thinking that this has to do with Zero Divisors. Specifically the nonexistence of them. Does that help?
that makes sense as far as explaining her misunderstanding...but what about the property of fields/integral domains that her mistake is related to?
Mindy is assuming "if ab= c then a= c or b= c" which is not true. It is a mistaken version of the "zero product" rule that says "if ab= 0 then a= 0 or b= 0". That, in turn is true because if a\ne 0 we can divide by it getting b= 0 and the reverse. That is where "no zero divisors" in a field is applied and where Mindy's mistake is. "No zero divisors" does NOT mean "no c divisors" for c non-zero.
Um, you don't get x=4 from both equations. If x-3=8, x=11, not 4.
Yeah, but by this time Mindy is so lost, it doesn't matter!
you are correct that she "should" get 4 and 11 but i guess it doesn't matter since her process and reasoning is incorrect. unless the professor made a mistake in typing this question...thank you both for your input.
