Undergrad How does ΔU relate to Cv in an adiabatic process?
In an adiabatic process, where heat transfer (Q) is zero, the change in internal energy (ΔU) is equal to the work done on the system (W), expressed as ΔU = -PΔV. The equation ΔU = nCvΔT applies specifically for ideal gases, where internal energy is solely a function of temperature, despite Cv being defined for constant volume processes. The discussion highlights the confusion regarding the relationship between Cv, Cp, and ΔU, emphasizing that ΔU cannot equal nCpΔT in adiabatic conditions. It is clarified that maintaining constant pressure contradicts the adiabatic nature of the process, as it would involve heat transfer. Overall, the key takeaway is that ΔU is independent of the pathway taken, reaffirming its reliance on temperature changes alone for ideal gases.
Tian En
For an adiabatic process, Q = 0.
From the first law of thermodynamic,
ΔU = Q + W on the system
when Q = 0,
W = -PΔV,
then why is it that ΔU = Cv ΔT when Cv is meant for the constant volume? We know that when there is work done, the volume is changing, and making use of Cv sounds like an contradiction. Please enlighten me. Thank you.
Let's split it into two processes: Change temperature from T1 to T2 at constant volume ΔU1 = Cv ΔT
Change volume from V1 to V2 at constant temperature ΔU2 = 0
ΔU = ΔU1 + ΔU2 = Cv ΔT
As U is a state function, ΔU is independent of pathway.
This is true only for an ideal gas (since, for an ideal gas, the internal energy is a function only of temperature).
Since U is a state function, ΔU independent of pathway, it means I can also use CpΔT = -PΔV, right?
No. $$\Delta U=nC_v\Delta T$$. On the other hand, $$\Delta H=nC_p\Delta T$$
I see. I have yet to learn enthalpy.
let's say for an adiabatic process, Q = 0, ΔU = W on the system = -PΔV, and ΔU = nCvΔT = -PΔV.
If we keep the pressure P, number of moles n and molar specific heat capacity Cv constant and we compress the system by ΔV (-ve) and hence we have -PΔV (+ve) and therefore the ΔT (+ve). However, the ideal gas law PV = nRT => PΔV = nRΔT implies ΔV (+ve) and ΔT (+ve) for constant n, R and P.
Previously, we have seen that ΔV (-ve) => ΔT (+ve), but now ΔV (+ve) => ΔT (+ve) from ideal gas law. Is there a contradiction?
Please tell me how you think you are going to compress the gas is you keep the pressure constant and don't remove heat.
So, this adiabatic equation no longer hold because by keeping the pressure constant, it violates the ideal gas law and by adding the term Q (-ve) to the equation, it becomes: ΔU = nCvΔT = -PΔV + Q (Isobaric equation)
I have no idea what you are talking about. All I can say is that, if you don't increase the pressure, you can't compress the gas (if the system is adiabatic).
when Q = 0,
W = -PΔV,
∆U=Cv∆T comes from the fact that whatever heat is added to an ideal gas keeping it's volume constant will only increase its internal energy and for an ideal gas internal energy is a function of temperature only.
Now we imagine that the system is undergoing an adiabatic process in which the heat added to the system is zero, and as per our knowledge of first law we know that the change in internal energy is a point function. Therefore if the states 1 and 2 are defined then ∆U will remain the same irrespective of the path undergone by a system . So in an adiabatic process ∆U =Cv∆T = W.
Hope this helps you.
Likes Tian En
I was just trying to relate the formula to physical impossibility. When there are inconsistencies in the formula, it is impossible to happen physically. i.e. By keeping the pressure constant, it can never be adiabatic, because Q is no longer 0.
It helps. Thank you. Since the change internal energy just as a function of temperature and previously I learned that ΔU ≠ nCpΔT but ΔU = nCvΔT, is it possible to relate Cp and ΔT to the ΔU?
It helps. Thank you. Since the change internal energy just as a function of temperature, I am looking at how to relate Cp and ΔT to the ΔU since previously I learned that ΔU ≠ nCpΔT but ΔU = nCvΔT, is it possible?
##\Delta U=nC_p\Delta T## is just plain incorrect. If you learned it that way, you learned it wrong.
Likes Tian En
For an ideal gas we have Cp=Cv+R (see e.g. heat capacity on wiki), so ΔU = n(Cp-R)ΔT.
Great, thank you.
  • · Replies 20 ·
  • · Replies 19 ·
14K
