araanandv2
- 26
- 0
Hi,
What is Banjo fitting?(In Aerospace)
Application of it?
Application of it?
The discussion centers around the concept of "banjo fitting" in aerospace applications, exploring its design, function, and potential uses. Participants share insights on its characteristics, compare it to other fittings, and discuss its presence in various contexts, including automotive and aerospace engineering.
Participants do not reach a consensus on the specific applications of banjo fittings in aerospace, with some suggesting automotive uses and others questioning their presence in commercial aviation. The discussion remains unresolved regarding the exact contexts in which banjo fittings are applied.
There are limitations in the discussion regarding the specific applications and definitions of banjo fittings, as well as the lack of detailed technical specifications or examples from aerospace contexts.
This discussion may be of interest to aerospace engineers, automotive engineers, and individuals curious about technical terminology and fittings used in engineering applications.
araanandv2 said:Hi,
Application of it?
Thank you Very MuchJoe Mechanic said:I can't recall seeing a banjo fitting on an commercial aircraft but I have seen them on automobiles. It is a doughnut shaped fitting that has fluid delivered to it via a tube. The doughnout is held to whatever receives the fluid by a bolt with a sealing washer; the doughnut hole is slightly larger than the bolt. The fluid comes down the tube, through to the center of the doughnut, through the center of the bolt and makes a 90 degree turn into whatever device receives the fluid. Where is it applied? I don't know. Maybe to a small aircraft's brake caliper?
Go to Google images and search for banjo fittings
