Why Does Calculating Ethanol's AFR Yield Different Results from Standard Values?
Calculating the air-fuel ratio (AFR) for pure ethanol yields different results due to the assumptions made about the composition of air. The balanced combustion equation for ethanol shows that oxygen is a key component, but it only constitutes 21% of air, leading to an initial calculated AFR of approximately 9.9. Adjusting for the presence of nitrogen and other gases in air, the AFR can be recalculated to around 8.95, which aligns more closely with the commonly accepted value of 9. It is crucial to clarify whether percentages refer to volume or mass to avoid confusion in calculations. Understanding these nuances is essential for accurate AFR calculations in theoretical and practical applications.
D19A99G
TL;DR
Calculation of the theoretical value of AFR of ethanol
First I have seen a few forums dotted about covering this subject already, however I couldn't find exactly what I was looking for so I apologise if its somewhere on here already.
I am trying to calculate the AFR value for pure ethanol.
I am only including oxygen in the category of "air" due to other elements being inert.
The balanced equation is C2H5OH + 3O2 = 3H2O + 2CO2.
When I then calculate the AFR while also considering that oxygen only makes up 21% of air, the value I get is approximately 9.9. Which is different to the widely used value of 9. Is there something I'm doing wrong or has the value of 9 only being achieved through practical tests which cannot be replicated via theory?
Ethanol mass = 46, Oxygen mass = 96
Air mass = Oxygen*4.76 = 456.96
AFR = 456.96/46 = 9.93
When; C=12amu, H=1amu, O=16amu
You are assuming that oxygen makes up 21% of a gas of uniform molecular mass 32 amu. You have to account for the fact that nitrogen is lighter.
Yeah ok, I can see what you mean. If I neglect the other gases which constitute the make up of "air" and assume oxygen = 21% and nitrogen = 79%. Then 3*(32+(3.76*28)) = 411.84. This would give me a AFR of 8.95 which is much closer.
Then considering Argon as well would give me a value of 9.01.
That makes sense thanks
Sadly, you can't generally assume whether a generic 'percentage' is volume, mass, or whatever. Units matter. I use '%wt' and %vol' to prevent confusion (and collisions with Mars).
I need to anneal 5052 aluminum for a home project. Google has given me mixed results on how to do this. Short version is that I'm doing some heavy forming on a piece of 5052-H32 and I'm running into issues with it work hardening. I've tried the Sharpie trick with a propane torch. But I'm not sure this is doing anything. I'm also seeing conflicting opinions whether to quench or air cool. So I'm looking for some expert opinions. (Oven heating is not an option due to size.) Thanks. edit: The...
