A. Neumaier
- 4,779
Please read my whole posts and don't make ridiculous arguments with meaningless theories!Dale said:Nonsense
As already said, the mathematical framework of a successful physical theory have (and must have) must have enough of their important concepts labelled not a,b,c but with sensible concepts from the world of experimental physics so that the subjective part of the interpretation is constrained enough to be useful.
For example, take the mathematical framework defined by ''Lines are sets of points. Any two lines intersect in a unique point. There is a unique line through any two points.'' (This defines the mathematical concept of a projective plane.) This is sufficiently constrained that every schoolboy knows without any further explanation how to apply it to experiment, and can check its empirical validity. There are some subjective interpretation questions regarding parallel lines, whose existence would be thought to falsify the theory, but the theory is salvaged by allowing in the subjective interpretation points at infinity. Another, more sophisticated subjective interpretation treating lines as grand circles on the sphere (undistinguishable by poor man's experimental capabilities) would be falsifiable since there are multiple such lines through antipodal points.
This shows that there is room for nontrivial subjective interpretation, and that the discussion of their testability is significant, as it may mean progress, by adding more details to the theory in a way eliminating the undesired interpretations.
What did you expect? A mathematical framework of 4 characters is unlikely to give much information about experiment. It says no more than what I claimed.Dale said:you cannot do an experiment with only that “experimental meaning”. It is insufficient for applying the scientific method.
Most theories are inconsistent with experiment, and only a few, successful ones are consistent with them. Only these are the ones the philosophy of science is about, and they typically are of textbook size!
They verify the theory if you measured a=2, b=3, c=6, and they falsify it if you measured a=2, b=3, c=5. Given your framework, both are admissible subjective interpretations. Your framework is too weak to constrain the subjective interpretation, so some will consider it correct, others invalid, and still others think it is incomplete and needs better foundations. The future will tell whether your new theory ##ab=c## will survive scientific practice...Dale said:Suppose I do an experiment and measure 6 values: 1, 2, 3, 4, 5, 6. Using only the above framework and your supposed “experimental meaning” do the measurements verify or falsify the theory?
Just like in the early days of quantum mechanics, where the precise content of the theory was not yet fixed, and all its (subjective since disagreeing) interpretations had successes and failure - until a sort of (but not unanimous) consensus was achieved.
